Results 1 to 10 of 15
Thread: Could a 2.0T owner have a look at a hose for me please....
    [Ex]Admin Duncan's Avatar
    Default Could a 2.0T owner have a look at a hose for me please....
    This one....
    If you stand at the front of the car and look into the bonnet just behind the two cooing fans on the radiator/intercooler assembly, look straight down towards the ground and you'll see it - it's fairly low down.
    I noticed on mine that it looks like it's got the beginnings of the hose splitting and it looks to me like the hose should be butted up against that little lip on the metal pipe.
    Could somebody confirm please. If it's on it's way out and is meant to be butted up to the lip, I think I'll just buy a new one and stick it on.
    Tyneside
    Off to look.......
    Cheers m8
    Tyneside
    Right had a look and there is U cutout on it, got a pic of mine will post it up in a min.
    Tyneside
    You can see the U cutout on mine, by the looks of it the pipe should be up against the lip.
    Cheers m8 - maybe I just need to slacken it off a bit and butt it up again to the lip bit. I'll try that first before I go off replacing anything. I haven't had any problem, just happened to spot it as I was having a nose in the engine bay. I'll do it one day in the daylight!
    Jul 2006
    Mexico
    Did you notice there is a line that marks the position of the "u"?
    I think your hose should be futher inn Duncan....
    Tyneside
    Not a problem m8 anything to help
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    ... bonnet just behind the two cooing fans on the radiator/intercooler assembly ...
    When I read that first I imagine you had found pigeons nesting under there
    Quote Originally Posted by BlueRob View Post
    There is a black line there, not sure if it's for lining the 'U' up to.
    Quote Originally Posted by MysteryElite View Post
    lol, didn't spot that typo!
    Quote Originally Posted by mark1319 View Post
    I nipped out, quickly jacked the car up to get access to the hose/jubilee clip and slackened it, repositioned it and tightened it back up......
    ...is that what yours looks like. Wasn't obvious from the pic but looked like it is.
    EDIT: Looks like your clip is a bit further away from the 'U' - probably doesn't really matter.
  1. Name that hose?
    By garetmcc79 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th May 2012, 17:09
  2. long time B owner - now a C owner
    By Mr.Mexi in forum Introduce yourself.
    Last Post: 22nd February 2011, 19:43
  3. vac hose on 3.2
    By hagga in forum Engine & Drivetrain
    Last Post: 3rd July 2007, 16:48
