Thread: Rear Brake Pads
    dudley
    Default Rear Brake Pads
    Hi All
    On my last vectra 1.8 energy, the rear brakes neaded replacing before the front brake pads- any idea's why?
    Chris
    Regular Member LJ sxi-nav's Avatar
    Winchester
    I had the same, my rear pads have just been replaced with 32k on the clock, fronts seem like they've got loads of meat left on them...
    Is it to do with the handbrake operating the rear calipers
    Jul 2006
    Mexico
    Quote Originally Posted by LJ sxi-nav View Post
    Could be mate...if you drive around with the handbrake on....
    dudley
    Default Rear brake pads
    Hardly likely.
    Although with the latest handbrake problem you never know. Perhaps the auto adjust for the handbrake is over keen and just keeps a little pressure against the disc.
    cs
    Winchester
    Quote Originally Posted by BlueRob View Post
    I always thought the little lever was an air freshener!!!
    When I put it down the smell of burning goes away!!!
    Jul 2006
    Mexico
    Quote Originally Posted by CHRISSMART41 View Post
    Hardly likely.
    cs
    True could be a good reason, but as the thread above you will smell it I guess...
    It`s an odd problem do to the fact that usually front brakes last less than rears
    Belfast
    Rear pads are softer - I've the same sort of wear on the Astra. 60k just clicked on the odo today, and the rears are almost down to the metal for the second time. Fronts are on their 2nd set of pads, and they were only on there because the original pads broke up a few months ago.
  1. Rear Brake Pads
    By tony-1977 in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2011, 18:25
  2. Rear Brake Pads
    By Das in forum Suspension, Wheels & Brakes
    Last Post: 3rd October 2010, 13:15
  3. rear brake pads
    By gdansk in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2010, 08:21
  4. Rear Brake Pads
    By steve-wolves in forum Suspension, Wheels & Brakes
    Last Post: 17th August 2009, 14:18
  5. Rear Brake Pads
    By cp123 in forum Suspension, Wheels & Brakes
    Last Post: 24th May 2009, 13:15
