Results 1 to 10 of 11
Thread: Sat Nav
    North West
    Default Sat Nav
    Apologies if this has been asked before but couldn't find an answer on a search..
    My dealer told me that my CD70 NAV unit allows postcodes to be used but cannot find it? Anyone no how to do it please
    Thx
    Mike
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    Don't think it is m8ty, you have to enter the Country/Town/Street to navigate with the CD70 head unit,
    unless I've missed something as well,
    Full Member Big Sig's Avatar
    Where you put the name in just put the post code in. I think it only takes the first 5 letters/numbers hth
    Regular Member Beavis's Avatar
    Blackburn Lancashire
    I think if I remember correctly you enter the postcode into where the town name goes
    Brighton
    Yes it does, well only a little bit.. Here goes..
    When selecting place name, Ie Bristol, Brighton or whatever, put the first part of the postcode in, the unit will display the areas matching that postcode.....BUT not all I have noticed.
    I use this method when I need to go to an industrial estate or somewhere that does not have road names or I don't know the full road name.
    Ideal for that, else just put the normal in
    Oct 2006
    Portsmouth
    Do you know what software version you are running, I think I have 2005 Ver 1.
    I'm sure I've seen some info on the net saying the current version is 2005 Ver 3.5 ?
    North West
    i will go and have a play. Thanks for the help
    Mike
    Oct 2006
    Portsmouth
    Me too, cheers
    Regular Member LJ sxi-nav's Avatar
    Winchester
    Yep, CD70 does do a postcode search as described above. It uses up-to 5 digits of the postcode, ie RG27 9
    As this will cover a larger area than a full postcode, the street/road list can be used and will only display the roads in that part of the postcode (IIRC), not as good a full search but a bit quicker than entering town etc...
    Regular Member Islander's Avatar
    Barrow-in-Furness
    Question nav. update
    Quote Originally Posted by markm View Post
    Is it possible to update the nav. and if so how is it done ?
