Thread: diesel fuel around injectors
    Regular Member robinhood66's Avatar
    Oct 2007
    nottinghamshire
    Default diesel fuel around injectors
    i just bought a SRI 150 CDti on taking the engine cover off i found diesel around all the injectors any ideas thanks
    leakoff pipes perished/split or leaking seals on the main fuel lines..
    diesel specialist time or VX dealer.... don't play with Common rail diesels unless you 110% know what you're doing,, the fuel under pressure can sever limbs....
    Oct 2007
    nottinghamshire
    thansk will go back to garage
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    What pressure does it run at
    dudley
    Default Diesel Around Injectors
    Firstly, do not mess with the pipes. Do not be tempted to tighten any of them. They have to replace any pipework which leaks. Tightening any union is not recommended and it can cause further leakage. I passed the common rail technology course in the summer and that was one of the no no's.
    When inspecting the top of the engine, first look at the inside of the cover. If any there are any tracking marks head straight to the dealer to get the engine inspected.
    Chris
    Quote Originally Posted by Ian S100 View Post
    I think around 16000psi
    Bristol
    Vehicle : CDTI 150
    Bosch quote 1350 bar for 1st generation to 1600 bar for 3rd generation common rail systems.
    Would certainly spoil yer day!!
  1. diesel injectors
    By deeks in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2010, 10:02
  2. How small are the holes on diesel injectors?
    By Celes in forum Engine & Drivetrain
    Last Post: 30th August 2009, 19:35
  3. Checking diesel Injectors
    By decho in forum Vectra C / Signum Troubleshooting
    Last Post: 28th December 2008, 13:27
  4. Tapping Diesel injectors
    By 98vectra in forum Introduce yourself.
    Last Post: 30th July 2007, 00:14
