Thread: door "cracking"
    Regular Member wardy's Avatar
    Chichester
    Default door "cracking"
    Last few weeks I've noticed the drivers door makes a horrible cracking noise when I open it. It seems to come from the metal strap/stop that prevents you opening the door too far (sorry don't know what it is called).
    I've tried lubricating it (where it goes into the endge of the door) and it goes quiet for a day or two and then comes back.
    I guess I'll have to get it replaced. Is it a common problem? and is it easy to change? Looking at it there seems to be some nylon rollers inside the door.
    cheers
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Think you are talking about the "check strap" Sounds like a new one is required if lube didn't work. Shouldn't be too expensive if not under warranty.
    HTH
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    AS bigP says - sounds like the check strap. Mine WAS changed under warranty
    copper grease... not oil..... that'll shut it up..
    Chichester
    Thanks guys. I think I've got some copper grease somewhere in the garage. I'll try that first.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    I had this sort of noise on an omega and one day the check strap pulled out of the door!,have a look at the door to see if it's flexing as you open and close it just to be safe.
    Nottingham
    I haven't look edat the Vectra to see what the stay looks like - but we have a galaxy and if I recall that made this noise - we found that the bolts holding it into the door were loose and the cracking noise was the threads slipping through the bolt holes in the door.
    Steve
    Chichester
    Took car in on Saturday (suspension crunching over bumps - another long story!)
    Anyway while it was in I pointed this door strap issue out & they said no problem it will have just worked loose & we'll tighten it up. Turns out it was already tight, but is worn out ! car is just over 2 years old & 27,000 miles!
    At least its being done under warranty.
    The copper grease didn't work, although it was a little quieter
    Gloucestershire
    Mine cracks all the time, much to my annoyance. Out of warranty, and the part was quite expensive as far as I can remember - £45+ i think. Any souces of cheaper parts?
    try LMF for reasonable prices on VX parts..
  1. Replies: 32
    Last Post: 2nd January 2013, 02:18
  2. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  3. Interior door sills and "b" pillar removal
    By si_hoss in forum Bodywork & Interior
    Last Post: 12th May 2011, 12:25
  4. central locking /"door open" Help!
    By tommoturbo in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2009, 07:22
  5. Unlocking door "press once" hack ?
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 16th September 2007, 19:54
