Thread: brakes squeak
    Jun 2007
    west yorkshire
    Default brakes squeak
    Hi I have a vectra 2003 model 2.2 dti.
    I bought this car about 5 months ago but it had its brakes changed etc in feb. But brakes have started to squeak. They only squeak when i im coming to a stop and speed is low around 30 or less.
    brakes were replaced in feb 2007 by vauxhall!
    any ideas?
    West
    Its mainly caused due to the lack of asbestos in the make up of the pads these days.
    You could try stripping & refitting, if the face of the pad has gone glass like then ruff it up a bit with some fine wet & dry paper.
    when refitting coat the back of them with copper slick too, this can help...
    If it does'nt help then another solution is to replace the pads with a more expensive softer pad, but with them being softer they will wear out quicker.
    hth...
    [Ex]Admin Duncan's Avatar
    Sounds like it just needs more Copaslip applied to the backing of the pads.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    As D says, try copper slip on the sliding surfaces and backs of pads NOT THE FRICTION SURFACES THOUGH.
  1. squeak squeak squeak squeak drive belt
    By martygibson1888 in forum Engine & Drivetrain
    Last Post: 8th February 2013, 17:20
  2. brake squeak squeak not a mouse!
    By paul.sessions in forum Handling & Braking
    Last Post: 22nd September 2010, 21:40
  3. squeak
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2009, 07:26
  4. Squeak !
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2009, 11:48
  5. Squeak
    By joules2.0t in forum Suspension, Wheels & Brakes
    Last Post: 18th October 2007, 20:30
