Thread: Hyperthetically speaking....
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    Default Hyperthetically speaking....
    IF I were to upgrade the front brakes on the car to the LMF 314mm type, Is it right and propper to do Upgrade the rears too to keep a balanced brake circuit??
    [Ex]Admin Duncan's Avatar
    No need to at all - you can stick with your 278mm rears.
    The 292mm rears (standard on a 2.0T/3.0CDTi and 3.2) will obviously add a bit more power for stopping, but it's not worth the hassle, or cost, to change the rear calipers (and other bits involved). Upgrading your 285mm fronts to 314mm will alone give you a big difference in stopping power.
    Feb 2006
    Wirral
    So the extra braking force at the front does not need balancing then?
    No, no need to balance up. The fronts do the majority of the braking as it is, so no specific need to upgrade the rears - unless you really want to.
    Feb 2006
    Wirral
    Cheers D. Just a thought the crossed me mind.
    One for the new year me thinks.....Nearly got the cash for me 100-400 EF-s L lens!!!
  1. A speaking clock
    By hoochydady in forum Comedy & Humour
    Last Post: 9th December 2011, 16:19
  2. polish speaking people
    By cranny 27 in forum General Chat
    Last Post: 18th September 2010, 15:46
  3. This is your Captain speaking...
    By s1nglef1sh in forum Comedy & Humour
    Last Post: 5th February 2009, 07:44
  4. Been speaking to Blaupunkt re CDC40
    By greeningr in forum Electrical & ICE (including SatNav)
    Last Post: 29th December 2007, 21:31
