Results 1 to 3 of 3
Thread: CDTi 150 Caterman fitting guide?!
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default CDTi 150 Caterman fitting guide?!
    Had a search and couldn't find one. Is there an online one?
    no need, it's just sooo easy..
    remove the engines cover..( it just pops off it's 4 studs, one in each corner)
    locate the fuel rail ( in the middle, a big cast pipe with steel tubes coming off it)
    disconnect the wiring to the right hand plug on the right hand end of the fuel rail
    plug the terminals of the box into the middle of this plug/socket setup ( you may need to trim the boxes lugs with a stanley knife)
    try and start the car, if you get a spanner light, you've got the connectors the wrong way round..it should start and run with no spanner light at all..
    Tain - Easter Ross
    Cheers bud.
  1. guide on fitting springs?
    By byers in forum Handling & Braking
    Last Post: 21st April 2012, 08:52
  2. guide on fitting springs?
    Last Post: 20th April 2012, 19:39
  3. Guide for fitting washer sensor?
    By lee gsi in forum Bodywork & Interior
    Last Post: 18th July 2011, 15:02
