Thread: Immobiliser problem?
    Regular Member rosssri's Avatar
    S.Lanarkshire
    Default Immobiliser problem?
    I popped into Asda to get my lottery and when i returned to the car i got in as usual turned the key and nothing happened no clicking or any other noises. The ignition lights came on but the starter didn't turn or even kick. It did this twice and then i thought it's a job for the AA then i rememberd i'd better remove the green tuning box before i called them.Anyway coincidence or not i then tried starting the car with box removed and it started no problem first time.I then reattached and tried starting and it started first time as well with no problem!
    Does this sound like an immobiliser problem to you's as surely if it was the tuning box that wouldn't stop the starter from turning over when the key is turned would it?
    If it was a problem with the immobliser then it would have the padlock symbol on the dash in the display. Did you see it?
    Regular Member VECTRAMAN's Avatar
    Bridgend/South Wales
    Vehicle : 1.9 CDTI Design Estate
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    If you try starting and it doesnt catch,just lock the doors again then open(using remote)this resets immobiliser and car will start as normal.This feature will reset nearly all immob faults on many new car makes and models.
    S.Lanarkshire
    Didn't notice it but i'll keep an eye out for it, if it happens again Vauxhall can have a look
  1. Little problem immobiliser
    By Fuzzynuts1984 in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2013, 17:57
  2. Immobiliser problem
    By sa07337 in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2011, 20:30
  3. Immobiliser.
    By bigjoe in forum Electrical & ICE (including SatNav)
    Last Post: 4th March 2010, 17:06
  4. car immobiliser
    By mrpatterson2008 in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2010, 22:27
  5. immobiliser/key problem, HELP NEEDED!!!
    By kgsric in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2006, 20:16
vectra c immobiliser bypass
2007 vectra 1.9 cdti reset imobaliser
vauxhall vectra c 1.9 immobiliser problems
vectra c immobiliser problem
vectra c turn off immobiliser
vectra imobilyser problem
vauxhall vectra 1.9 cdti immobiliser problem
vectra 1.9 cdti 07 bypass immobiliser
vauxhall vectra immobiliser reset
vauxhall signum 1.9 cdti imobilizer problems
vectra c 04 immobilizer problem
bypass diesel pump immobiliser vauxhall vectra c
how to reset immobiliser on vectra c
vectra diesel resetting immobiliser
vectra c 1.9 immobiliser not working
vauxhall vectra c padlock symbol
reset immobiliser opel vectra c
opel vectra immobiliser problems
