Results 1 to 10 of 11
Thread: Knocking noise? Any ideas
    middlesbrough
    Default Knocking noise? Any ideas
    When driving very slowly such as through traffic jams or when just sitting idle i get a knocking noise, not sure if its coming from front or back though. Is this normal does anyone else have this problem or should i be getting it looked at.
    SCOTLAND
    if its from the front its probably your radiator mount bushes. i had mine done under warranty and i think its a common fault
    middlesbrough
    well mines still in warrenty so ill get it done, cheers for that info graeme.
    Regular Member HighlandGraham's Avatar
    Scotland
    Greetings to you Andys,
    I too have a knocking/cracking noise coming from my car, it happens at all different times and speeds. I had this on my last Sri too so I know exactly what causes my noise. Its generated from the suspension, movement between the springs and their seats. Vx do have a fix for this. They fit rubber tube liners to the last few coils of the springs and it sorts it out. I have notified my local Vx and the have asked me to bring the car in to have the fix carried out. This fault is also listed on the Vx TIS disk under a Technical bulletin.
    I have been told that Vx reckon that this problem only exists north of the boarder here in Scotland, so there is a very good chance that this is what is wrong with yours too.
    This is a copy of the TIS service document.
    Field Remedy: 1563
    Subject: Cracking noise from front section - Temporary cracking noise from front section
    Models: Engines: Option:
    Vectra-C 2002... All All
    Complaint: Temporary cracking noise from front section.
    Cause: Misfit between spring and lower spring seat.
    Production: None.
    Remedy:
    In case of customer complaint paint front springs in the area of lower
    spring seat and install protection sleeves.
    Qty.:Partname: Partnumber: Cat.-Number:
    2 Protection Sleeve 12802932 3 12 401
    Regards sent
    Steven
    Quote Originally Posted by HighlandGraham
    Afraid not Graham, its country wide. Its an extremely common problem and something they had still not fixed on 05 cars despite knowing about it for 3 years. Hopefully they did something at the start of the facelifts.
    Regular Member Basil's Avatar
    Nottingham
    Does the same FR cover the rear too or just the front, as I have a cracking noise coming from the rear and the symptoms are virtually identical to what graham described.
    Noise at the rear, are you sure its a suspension kind of sound? the reason being that another common fault is a missing spot weld between the inner and outer frames of the shell. The two peices then bangs and knock. The fix is a dealer applied rivet to the c plillar. Again there should be a FR sheet for this.
    Scotland
    Greetings to you Andy,
    I thought it a bit strange that this suspension fault could only exist here in Scotland.
    Unfortuneately they have not sorted it out on the facelift, as it is the facelift Signum which I have and the noise is still being generated. I will soon be taking mine in to get it sorted and I am confident that the fix will last as it lasted well over two and a half years on my Sri Vectra C.
    Regards sent
    Steven
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    Smile
    Quote Originally Posted by Andys
    hi m8 i had the same problem done under warranty just after got the car a small prob didnt take them long to sort
  1. Knocking noise
    By welshboy in forum Suspension, Wheels & Brakes
    Last Post: 22nd December 2011, 12:28
  2. knocking noise
    By winnie2457 in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2010, 21:06
  3. knocking noise please help
    By wreksta in forum Engine & Drivetrain
    Last Post: 16th February 2008, 17:54
  4. knocking noise
    By silky in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2007, 00:07
  5. Knocking noise
    By Triple Trouble in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2006, 11:47
www.WReksta.In
