Results 1 to 10 of 22
Thread: Maths question on a Goverment learning web site - and it's wrong!!! lol
    Default Maths question on a Goverment learning web site - and it's wrong!!! lol
    Just checking I'm not losing my marbles here.
    Was browsing on the BBC site and reading an article about literacy/numeracy - it had a link to the Learn Direct site where it had a couple of quizzes so I thought I'd give the Maths one a whirl. (I chose the 20 question option.)
    Question 2 stated....
    "A milk jug holds exactly one pint of milk. If one pint equals 0.568 litres, how many millilitres will it hold to the nearest hundred?"
    Options were A. 100ml B. 500ml C. 600ml D. 1100ml
    I chose B. 500ml, only to be told that I was wrong and that the correct answer was 600ml!!
    Now I understand that 600ml is the nearest hundred in terms of rounding up/down - but the question was "....how many millilitres will it hold to the nearest hundred?" How on earth can a 568ml jug (as that's what it is - clearly stated) hold 600ml?! - it can't!! The nearest hundred it can physically hold is 500ml.
    I'm not missing something here am I? - my reasoning is sound?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    I understand your reasoning but one could always argue that there is exactly one pint of milk in the jug and not 'a 1 pint jug is full of milk'. May be a case of read the question but i agree with your query.
    I think the is saying that there is a jug holding exactly 1 pint of milk, but to nearest 100ml, how many mililitres should the jug be in volume to accommodate the 568ml.
    All I can say - clumsily worded question - as most maths questions are!!!
    Jul 2006
    Mexico
    Well D it`s a question about numbers.....not logic....I get you point, but it`s just a matter of going from LitTer to Ml. and then rounding it up...yeah you are right 600 ml. wont fitt on a 568 bottle
    Quote Originally Posted by Gazza4 View Post
    Yep, can see your reasoning there, although the first part of the question...."A milk jug holds exactly one pint of milk" to me says that it only capable of holding a pint, as opposed to it currently holds a pint but can hold more.
    I understand your reasoning but one could always argue that there is exaAll I can say - clumsily worded question - as most maths questions are!!!
    Yep! As you say it may not be implying that the jug holds a maximum of a pint, merely what it's currently holding! Very badly worded question!!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    In maths you are always told the rule greater than 0.5 round up, less than 0.5 round down unless circumstances make rounding in a certain situation impossible. If you in exam and chose the 500ml, with an explanation to the side you would get some or all of the marks because you would be demonstrating you understand these circumstances in this question.
    But in all honesty I doubt anyone can fault your finding.
    Regards,
    Yep, that's what I was saying. I totally agree that the 600ml answer is the nearest 100ml using the rounding up/down method - straightforward. As you've seen, my 'issue' was that they implied that the jug held exactly a pint (568ml) so the nearest 100ml it could hold would be 500ml as it physically couldn't hold 600ml.
    Just a very badly worded question if they weren't meaning the jug could only hold a pint. Can I be arsed to e-mail them? - nah, sod that!!
    Here, there and every where!
    Too early in the morning for this, in the context of the question 600ml is correct. In the real world 500ml would be correct.
    I've just done a quick Mensa test and considering the time of night (or morning) got 28 out of 30
    http://www.mensa.org/index0.php?page=12
    It is hard to think straight when it's done correctly against the clock.
    The question and answer are both correct, based on the grammar
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    I see your logic D.
    I guess their arguement is that the jug will hold 568 ml. If the jug is holding 568 ml then to the nearest 100 its holding 600 ml.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Sorry D, but the answer is indeed 600ml. Rounding 568 to the nearest 100 would be to 600. I've got an 'A' Level in maths, but that may not be enough....
    Since when has maths been logical??
  1. maths question
    By shoota70 in forum Comedy & Humour
    Last Post: 1st August 2010, 18:48
  2. 5th grader maths question....
    By Deztroyer in forum The 'Off Topic' room
    Last Post: 13th May 2009, 02:50
  3. Maths question?? this is doin my head in.
    By macdad in forum The 'Off Topic' room
    Last Post: 6th March 2009, 21:45
