Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Poorly Signum
    Leicester
    Default Poorly Signum
    Well, yesterday the Signum started to act a little limp wristed, power really backing off after 3000rpm, switch it off and back on again and all is well, until you hit 3000rpm and the same thing happens.
    It turns out that this is the device that is causing all the trouble, well this is the new one........
    It is the fuel pump, all £2092 + VAT worth!!! (Retail)
    So after driving up to Marshalls yesterday, they had it on Tech 2 within 20 minutes, and had a diagnosis within 35 minutes. Due to the cost of replacement, a case number from Vauxhall was required.
    Two hours later and the parts were ordered, and work started this morning, heres a few pics of the progress so far.
    Finally, here is the culprit!!! The failed fuel pump.
    My engine number was recognised by Vauxhall as having a potential issue with the fuel pump, so it was authorised with no problems. Not that I expected any problems.
    Not all bad news though, apart from the fact that Marshall's and Vauxhall got on with the job with no hassle at all, the Signum will also get a new cam belt kit and an oil and filter change as part of the job!!!!
    They also gave me this as a courtesy car!!!
    A 2007 Vectra SRi XP 1.9 CDTi 150, with VXR 18's and a VXR PC Re-map.
    I can't praise the dealer and Vauxhall themselves enough for just getting on with putting her right with absolutly no hassle to me.
    It's not nice to have you car go wrong, in fact this is the first CDTi Vauxhall I have owned that has gone wrong!!
    Hertfordshire
    That looks like a hell of a job to change as well !!!
    Looks well buried, must be a few hours labour there !!!
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    88 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Ouch..!! thats a serious bit of money for that pump.. glad its being sorted under warranty for you, back up to VXRPC when its done then....?
    Chester
    Two grand plus VAT. !!!!!!!!!!!!!!!
    OMG.
    Leicester
    Quote Originally Posted by Big-Pete View Post
    Will be well over £3000 when done, by the time you have added the labour, gaskets parts fuel pipes (which are usable once) oil/filter and cam belt kit ect which has to be removed apparently to do the job.
    I am not going to bother Pete to be honest. I have a theory on this...
    I have always found my Signum to be a little slower on acceleration than other 3.0 Signums I have driven, now if my pump has been under performing since I had the car, the new one should run to it's full capacity, so this in turn should offer a little better performance.
    So I'll leave as is. It has the latest software from Vauxhall anyway so it should be a nice drive when I get it back.
    May 2007
    Home or in the Gym
    88 Post(s)
    Vehicle : Audi Q7
    Engine : 3.0 TDV6
    Mileage : 3023
    Sounds good, hopefully the pump will bring it in line with others you have driven as you say, they managed fit you in quickly ...
    Leicester
    I have been dealing with them for years, I was supposed to be going away in the caravan for the weekend but I doubt this will happen now, but they are doing their best.
    Jun 2007
    Sittingbourne, Kent
    Hope you get it back quickly mate .
    spoons
    Guest
    Nice to see you back in a Black Saphire Vectra XP Matt !!!
    Sorry to see your pomegranite under the knife though !!
    Regular Member nickc's Avatar
    Jul 2006
    newport, shrops
    glad that is sorted under warranty
    just thinking about the back ache the vx mechanic (pic 3) is gonna have if he is bent over cars like that all the time! ouch
  1. My poorly car is going in I can't take it no more
    By pipamish in forum Suspension, Wheels & Brakes
    Last Post: 16th February 2013, 10:27
  2. A very dirty, poorly Signum
    By BigWilko in forum Quick Photo Album
    Last Post: 27th June 2011, 10:32
  3. Poorly 2.0T Signum
    By chill_za in forum Engine & Drivetrain
    Last Post: 31st May 2011, 14:50
  4. car is poorly
    By andy.l in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2008, 09:24
  5. Poorly VXR
    By MattB in forum Spotted or put a flyer on a Vectra C/Signum?
    Last Post: 10th August 2007, 20:29
