Thread: Rear suspension bushes
    Regular Member dan1983's Avatar
    North London
    Default Rear suspension bushes
    Does anyone know where i can get some rear bushes but not vx ones.
    Only me....
    seriously thou...I don't think anyone yet does polybushes for the vec C...mostly it's OEM style void bushes or pattern copies..I've certainly not seen them listed yet..
    North London
    where can i get them from vx? how much? and are they easy to fit?
    I think thats what i need cos on the rear passanger side when i go over bumps it wobbles.
    sounds like the top arm bush,, but get it checked first before buying..thou they are usually the first one's to go..as it's a multi link suspension system there are around 7 bushes per side on the rear, so finding which one is shot is the first task..
    if it is the top arm, then get the whole replacement arm of ebay for around £30 and it's only 2 bolts to fit it then, rather than having to press bushes in/out..which is just grief to avoid..
    North London
    How will i know? is there anything to look for? Thanks
    you'll need a prybar or large screwdriver and try to work it inside the arm between the bush and the arm.. if there's excess movement, then that bush is shot..can you rock the top of the wheel in and out or side to side..????
    North London
    not sure will check tomorrow. Thanks
    Full Member
    Mar 2007
    Finland
    Would these http://www.k-mac.com.au/Kmac_catalog.pdf do any good? See page 4.
  1. Suspension Bushes
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2010, 09:11
  2. Replies: 5
    Last Post: 21st March 2010, 12:34
  3. Rear Suspension Bushes
    By Keithy in forum Suspension, Wheels & Brakes
    Last Post: 19th December 2009, 18:12
  4. Rear suspension arm bushes : How much to get done?
    By RSV_Ecosse in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2009, 23:24
  5. I'm ooking for rear suspension arms and ARB bushes?
    By monkeez in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2009, 11:42
