Thread: Emmisions light
    Regular Member dan1983's Avatar
    North London
    Default Emmisions light
    Hi can anyone help. I put a k&n filter on my 2.0t (sounds great) but my emmissions light is constantly on, it actually came on when i did my air box mod originally. My mate reckons its the lamda sensor. any ideas?
    check the Mass airflow sensor connection as a first off..
    it has to be something you disturbed when you fitted the K+N and did the mod..don't just swap out the lambda but retrace your steps first, then get the codes read if it still won't go out..I lay good money on the lambda sensor being fine...
    North London
    What codes? I did go off for bout a week or so.
    when the emissions light comes on, the ECU's store a fault code to tell the techie what actually is wrong with the car..so a trip to VX to get the codes read ( or any garage with an OBD-II compliant scantool with live values) will be no end of help in sussing out whats going on..but if it's coincidental with you installing the K+N then i'd start looking at the MAF and it's wiring first..
    North London
    Thanks will check first cos didnt want to fork out on vx telling me whats wrong then charging me again to do it
    thats the beauty.. they tell you whats wrong, then you just take it away and get it done somewhere cheaper.......
    North London
    yeah but they charge you to tell you whats wrong
    yep, as will anyone......But £45 is still cheaper than a lambda sensor, if thats not whats wrong with it..
  1. ENGINE LIGHT ON AGAIN (emmisions light)
    By sla002 in forum Engine & Drivetrain
    Last Post: 21st March 2012, 22:09
  2. misfire and emmisions light
    By paul515 in forum Engine & Drivetrain
    Last Post: 2nd August 2011, 23:17
  3. emmisions/ engine light on !!!!!
    By donniecdti in forum Engine & Drivetrain
    Last Post: 21st January 2011, 20:45
  4. emmisions light update guys
    By nph1 in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2009, 11:14
  5. Exhaust emmisions light
    By lcirillo in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2009, 13:37
