Thread: 2.0 diesel ecu & Foglights
    Regular Member cornishpirate's Avatar
    Cornwall
    Default 2.0 diesel ecu & Foglights
    Off to the scrappy again tomorrow.
    After reading lots of posts about fitting foglights to ls models can anyone tell me if it would work ok if i was to fit the ecu from a veccy that was fitted with foglights at the factory would i then be able to have the lights working from the proper Vx switch?
    Also where will i find the ecu on a 03 plate 2.0 deisel
    in a word no...forget it..
    there's more than one ecu on these cars and it's not as simple as all that..
    Cornwall
    oh well I guess its rocker switch in the dash then unless anyone has managed to hardwire into the original switch without upsetting the can-bus thingy???
    i don't think it can be done like that, as the switch only sends pulses, not old style fixed feeds..the switch is CANBUS as well..
    Cornwall
    oh you just like to destroy all of my dreams !!
    thanks for the quick replies i'l stick to the rocker switch. do you know if it will be ok to tap a feed for the relay / switch from the side light circuit?
    it may upset the lighting controller if you do...for an Ign feed, i'd tap out of the cigarette lighter..no canbus watching over that circuit and plenty of current avaliable spare.
    Cornwall
    ok i will do it that way
    thanks for your help
    Feb 2006
    Guttedsville
    can't get any easier.....
    Cornwall
    Quote Originally Posted by AndrewTi View Post
    yes mate already read that one but just wanted to kn if i could use some of the original equipment to save drilling holes and the like
  1. foglights
    By signumturbo04 in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2012, 23:52
  2. Foglights?
    By gerry89 in forum Styling
    Last Post: 1st July 2011, 09:44
  3. Which foglights for this
    By awilson in forum Bodywork & Interior
    Last Post: 9th May 2011, 21:46
  4. Foglights
    By Tam80 in forum Electrical & ICE (including SatNav)
    Last Post: 24th September 2010, 10:33
  5. Foglights?
    By ashdog in forum Styling
    Last Post: 15th June 2006, 18:04
