Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: Got a nifty bit of (Pocket PC) accelerometer software..
    [Ex]Admin Duncan's Avatar
    Default Got a nifty bit of (Pocket PC) accelerometer software..
    After seeing other threads about 0-60, 30-50 and 1/4 mile times it made me wonder if there was a bit of software out there for a Pocket PC that would let you record these. One quick search on a site I use for software and voila!, found just the job.
    It lets you record any range of speed acceleration, 1/4 and 1/8 mile standing starts and lets you define a circuit to then do lap times.
    Bunch of screen grabs to illustrate.
    BTW (before anyone comments ), most of the times are me just pootling around, not aiming to get the best times. Although I did have a couple of attempts and managed to get a 2.65 and a 2.7 for a 30-50mph in third - and that was it being a bit wet/greasy.
    Initial configuration screen. GPS settings (wired or Bluetooth - what I use although I have a backup wired one too. ) set here, along with speed units.
    Main menu showing all the options.
    Acceleration timings. Choose the range that you want to measure. As soon as you hit the lower limit the timing starts, stops when you reach the upper limit. If you make a mess of the run you just hit the 'Forget Last Run' button and it's removed from the stats. To do another run you just drop below the lower limit and go again as many times as you want to. All the time it shows the best time and averages out the times.
    You can then go into the Records section and plot out graphs.Just chose which results to plot.....
    Speed
    Distance
    Acceleration
    Distance timings - choice of 1/4 or 1/8 mile. Car needs to be at rest, timing starts when car starts to move.
    Again, you can plot as many runs as you want to compare.....
    Lap Timings - very nifty feature.
    First thing to do is drive a lap of the circuit - it can be a closed loop circuit (like most are) or an end to end circuit (i.e. where the start line isn't also the finish line). You start driving, tell it where the start is, drive the circuit and then tell it where the end is. You then give the circuit a name. You can then fine tune the circuit e.g. adjust where the start/finish is if that wasn't where you started recording the lap from. You can also add split time points on the circuit so that they show up as you pass these points on the lap.
    As soon as you cross the start line the timing starts and stops when you cross the finish. If it's a loop circuit then timing automatically starts for the next lap and so on. Always shows the last time and best time.
    Again, you can go into the records section to pull up any lap(s) and get the data/graphs for them.
    So, overall a really neat bit of software and not too expensive. Obviously as it relies on GPS, as opposed to a physical measuring device on the car, it won't be 100% accurate as GPS fixes can vary in their accuracy - but they won't be too far off and certainly give a good indication.
    As my kit is transferable between cars, it could be fitted into another car at a meet to let people have a go.
    Here, there and every where!
    Funky software D. I like that, might have to buy another PDA
    Feb 2006
    Guttedsville
    Pah, we use TomTom and beat its suggested Clermont Ferrand to Paris time by, was it 50 minutes!!
    We don't do things by halves!!
    Quote Originally Posted by AndrewTi View Post
    tickets in the post....
    Feb 2006
    Guttedsville
    I think there actually is......
    Regular Member jonesy_ni's Avatar
    Co Antrim
    Interesting!
    Regular Member In a states's Avatar
    Dec 2005
    In an estate car
    spoons
    Guest
    Very interesting indeed........
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Cool, I might get the trial and see if it will work in my PDA...
  1. ok guys any of you own a nifty fifty lens?
    By hoochydady in forum Gen Photography
    Last Post: 7th February 2013, 15:05
  2. Pocket PC Mobile Phone rrp£300
    By danlat1415 in forum General items for sale
    Last Post: 31st July 2007, 21:09
  3. HP IPAQ 1910 PDA Pocket PC
    By RSV_Ecosse in forum General items for sale
    Last Post: 29th July 2007, 16:37
  4. Use your TomTom as an accelerometer!
    By 2ltrT in forum General Chat
    Last Post: 15th February 2006, 07:46
  5. Pocket PC help?
    By Jay in forum General Chat
    Last Post: 30th September 2005, 08:48
