Thread: Broken Wheel Bolt
    Regular Member cornishpirate's Avatar
    Cornwall
    confused Broken Wheel Bolt
    I have snapped a wheel bolt in my front hub and need to remove the broken bit.
    Any ideas?
    CP
    Full Member Big Sig's Avatar
    Can you tap it round with a centre punch and hammer or with a chisel? Drill a hole and use an "easy out"??
    drill it all the way through...
    remove the wheel, the caliper ( hang it up out of the way), the caliper carrier ( 2 torx bolts) and the disc ( 1 tiny torx bolt)..
    Now you have a clear veiw, centre punch the broken remains and using a sharp drill thats around 6mm bore all the way through.. then just work up is sizes till 1 of two things happens..
    1: the heat generated breaks the pinch on the threads and the remains unscrew themselves towards the back of the hub
    2: the bolts core is so weakened that you can then centrepunch one side in on itself and extract the remains with a pair of pliers..
    OOp's i know all about this as i broke two bolt's in the same hub about a month ago managed to get one out but the threads were totalled so ended up putting a complete stub assembly on from the breakers only £40 so not to bad !!!!!
  1. Wheel bolt help
    By neill in forum Suspension, Wheels & Brakes
    Last Post: 31st August 2012, 02:05
  2. Crap wheel bolt key
    By CK1 in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2012, 21:05
  3. wheel bolt size?
    By swifty_53 in forum Handling & Braking
    Last Post: 23rd March 2011, 17:50
  4. Wheel Bolt Caps??
    By OPC in forum Suspension, Wheels & Brakes
    Last Post: 7th April 2010, 22:27
  5. Wheel bolt size
    By Brocks in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2007, 08:40
how to remove broken wheel bolt vectra c
