Thread: no power
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    Default no power
    please help me!!! started to put a sound system in my vec took the door cards off changed the speakers and run oxy wire throw the doors to the amp etc etc. couldnt get it to work propaly so took it all back out and now i have no power to the n/s/front door i.e electric windows, central locking and no electric door mirror. ive checked all the wires for breakes and nothing any clues what this could be many thanks,
    Jul 2006
    Mexico
    Did you check the fuses mate?
    Regular Member shan's Avatar
    Is your window working on the other side?
    From experinece mate. The fault will only be at the connection at the door jam or maybe even a fuse if all the windows are not working. I think it's the connection at the door.
    Hope you sort it.
    checked all the fuses under the bonnet, side of the dash and in the boot drivers door electrics work fine and the n/s wont opperate for the drivers side neather.
    It has got to be that conection. If you have not removed anything else. Is it a plug and socket type. I think maybe it's not connected quite right or maybe the pins in the plug/socket have been bent or pushed back and are not makeing a connection.
    Do you have a multi meter? If you do check the feed at the connection before it go's into the door. If ok connect it and then check feed at say door switch.
    ill check that out tommorrow, but the speaker still works thats what is so confuseing
    Have you checked the switch connectors too?
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Signum Sluggish low power, Limp mode at high power.
    By Bigg943 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th June 2011, 18:55
  3. Signum Sluggish low power, Limp mode at high power.
    Last Post: 5th June 2011, 11:30
  4. Replies: 11
    Last Post: 7th January 2010, 17:50
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
