Thread: rear springs
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Default rear springs
    Hi i need to replace the rear springs on my signum does anyone know if this a hard job to do ?.
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Quote Originally Posted by Daywalker View Post
    If its the same as the Vectra, its a doddle, 2 bolts each side at worst!
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    its in the How2 section.........
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    looked in how 2's but could only see rear shocks and not springs
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    hi m8 take the rear wheel off and you will see the lower arm undo the nut and bolt (18mm) and then leaver the arm down and the spring is free to
    resembly do it in reverse good luck
    nearly safe....
    raise and support the car approx 14 inches high under the subframe on axle stands..
    Place a trolleyjack under the lower alloy arm and take up the tension, then using an E18 socket and 18mm ringspanner undo the lower crossbolt and remove it, then gently let the trolley jack off.. the lower arm may need a little levering to help it fall, but you want to control the springs extension with the jack's retreat..
    when the arm is down, pull it off the isolating rubbers and change the spring
    jack the arm up into position and reinsert the crossbolt..tighten the nut and bolt and then replace the roadwheel and the job is done...safely.....
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Cheers will have a go at weekend
    it's dead easy.. trust me..
    Jan 2006
    Skynet HQ EMEC#5
    Mark, you must have fitted a few to be able to give such a detailed procedure
    one or two cars now....
  1. kyb rear springs
    By markmac21 in forum Suspension, Wheels & Brakes
    Last Post: 5th July 2012, 14:16
  2. Rear Springs - which ones?
    By Di frost in forum Suspension, Wheels & Brakes
    Last Post: 7th May 2012, 20:55
  3. Rear Springs
    By bobmcn in forum Suspension, Wheels & Brakes
    Last Post: 5th May 2012, 20:43
  4. For Sale: SRI rear springs £10
    By Jow20 in forum Parts for sale
    Last Post: 25th January 2012, 17:57
  5. Rear springs
    By bertbuckie1 in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2009, 17:26
