Thread: Engine Timing/Idle
    Regular Member Andy17899's Avatar
    Jun 2007
    West Midlands
    Vehicle : Vauxhall Vectra SRI XPII
    Mileage : 68K
    Default Engine Timing/Idle
    Hi all, my 1.8 52 plate SXi, when i pull up at a junciton, or even when i just start the engine or whatever, when its idling its idling quite low, about 600 revs, and just feels like ive just started to lift the clutch..
    how do i go about making it idle higher..?
    down to the dealers and ask them to use Tech2 to increase the idle speed for you..
    Jun 2007
    West Midlands
    Mileage : 68K
    ouch, expensive?
    could it be a sticky idle valve?
    Full Member Big Sig's Avatar
    they may charge you £30 or so, I'd ring them and ask. With it being all electronic i'm not sure there is an idle valve anymore? Anyone?
    Jun 2007
    West Midlands
    Mileage : 68K
    ahh absolutely skint at the moment, even for thirty will get it done once i get paid
    no cheaper way. like anyone with a tech 2 machine?
    Quote Originally Posted by Andy17899 View Post
    ouch, expensive?
    it doesn't sound like.. sticky idle valves make them cut out, not idle low... and as Bigsig said, around the minimum charge for tech2 to do it, so £45ish quid should see it put right.
    southampton
    my 52 plate sxi idles at around the 600 mark is it not normal to be this low? ive ever had any problems with it
  1. Rough idle after timing belt change
    By bcoss in forum Engine & Drivetrain
    Last Post: 4th June 2011, 09:57
  2. Engine won't idle! Help!
    Last Post: 5th December 2010, 17:43
  3. engine idle on the 150 cdti
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 11th January 2010, 20:21
  4. engine on idle
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2009, 12:33
  5. Replies: 4
    Last Post: 31st July 2008, 15:29
