Results 1 to 10 of 10
Thread: Z22YH In Need Of A Timing Chain...
    Regular Member simp_2.2sri's Avatar
    Sep 2007
    Cheshire
    Exclamation Z22YH In Need Of A Timing Chain...
    The on going saga of my strange rattle continues...
    I took off the aux drive belt yesterday and started the engine with my fingers and toes crossed hoping the rattle would be the alternator or the air con compressor or maybe even the belt tensioner......its not With the air box out and with access from underneath I would say the noise is defo coming from the timing chain Iv'e only had the car 2 days!!!
    The noise seems more noticable when youre actually driving down the road, it sounds like a ****** D reg ford escort with a 1.1 litre push rod engine
    The garage I bought it from says they've "serviced" it but to me the oil filter houseing and sump plug bolt don't look like they've been touched recently, will some fresh decent oil make a difference?
    Maybe its the chain tensioner that has failed? can you change just the tensioner or is it a case of while you've got it in bits you might as well replace the chain too? I really don't like driving it while its making this noise but its the only form of transport I have, my **** goes every time I turn the key
    Any advice would be fantastic thanks...
    halifax west yorkshire
    Default hi
    sounds like the chain mine rattled for afew seconds on start up but got worse took it to the dearler the sid the same but done under warrenty
    Regular Member rickyroo's Avatar
    shropshire
    Mate def the chain, your right might as well do the tensioner and chain together, cost roughly £160 as a complete kit if your brave enough to do the job yourself, at the stealers roughly £750.
    Technical directors office
    I'd complain to the garage and see if you can force their hand into fixing it FOC for you..
    If they won't, and you don't fancy doing it for yourself, then drop 'Benny' a PM either on here or on z22se.com and he'll do it much cheaper than VX prices..
    The garage claim to have serviced it??.. is the oil new or dirty? that'd tell you for sure..
    I wouldn't advise just replacing the tensioner.. if it's rattling well, then i do fear it's chains..
    Jan 2007
    morton
    yep ! take it back and give them hell ! OR just get the chain done ! its better than the alternative ! EEK !!
    Regular Member rayvo-gsi's Avatar
    warrington
    I had this problem on my 2.2SRI after a week of ownership.Took it back to were i bought it from and told them if they did'nt sort it then they would get a visit from trading standards.They soon sorted it
    I thought vx had sorted the old problem of the rattly/breaking chains on the 2.2 petrols?
    they did, back in 2001... but they will still wear out eventually.. they are not for life..
    Some will wear out quicker than others as well.. it's a factor of how well you keep the oil clean, so service overand above the schedule to avoid early trouble..
    You very rarely hear of the DTi's chains wearing, are they different/stronger?
    different engine all together mate.. chalk and cheese..
  1. Z22yh Balancer shaft chain help
    By andrewleighton in forum Vectra C / Signum Troubleshooting
    Last Post: 14th May 2012, 16:21
  2. chain tensioner z22yh
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2012, 10:47
  3. Z22YH Cam Chain Rattle @ 41K Miles??
    By Stevie76 in forum Engine & Drivetrain
    Last Post: 16th January 2012, 20:51
  4. Timing chain kit Z22YH
    By Sambor in forum Engine & Drivetrain
    Last Post: 2nd September 2011, 10:27
  5. Timing chain kit please help!
    By benholden2010 in forum Engine & Drivetrain
    Last Post: 24th August 2011, 20:56
z22yh chain tensioner
