Results 1 to 10 of 22
Thread: Nail in tyre
    Regular Member izonoky's Avatar
    Aug 2007
    London
    Default Nail in tyre
    Noticed this last night, I've no idea how deep its gone in. As you can see the tyre's still inflated. I've tried pulling by hand but it wont budge. I'm worried if I do pull it out the tyre will go too (or will it be ok?)
    Regular Member G.O'Rilla's Avatar
    Jul 2006
    On the road
    In the shoulder - doesn't look repairable to me.
    The experts on here will confirm/deny
    [Ex]Admin Duncan's Avatar
    It's looking like it's in the area where it may not be repairable, but it's very close - it may be repairable.
    It all depends on the length of the nail TBH, it may just be part of a broken nail and hasn't broken the inside wall. What I'd do, if it was me, is either drive down to your tyre place and get them to pull it out there and see if it then starts to leak air. If it does then you're in the right place for a repair/new tyre if needed.
    Other option is to pull it out yourself and see what happens. No leak then you're fine. Leak, then you'll have to pop on the spare and take the wheel to the tyre place.
    Aug 2007
    London
    ur right Duncan, I'll pop down to Quikfit next week. fingers crossed.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Thats unrepairable,even if it doesn't leak it could have gone down to the cords which aren't meant to be exposed and they could weaken and weaken the tyre.
    Well, there you go - from a man in the know. Bummer izonoky, looks like a new tyre! Pity as it looks like you've got a decent bit of tread left!
    Aug 2007
    London
    booga, if that's really the case, I'm looking at the cost two rear wheel tyres, I can't see the tyre centre replacing just the one. They've only done 7200k.
    Why not? If only one needs replaced then that's all you need to do.
    Aug 2007
    London
    the wear will be uneven, that's my thought. (I'm tempted to leave the damn thing in there, it doesn't appear to be interfering with the main tread, just get the pliers and clip the head and some of the neck)
    Quote Originally Posted by izonoky View Post
    Not really a problem. It's a bit of a misnomer that you need to replace both tyres if one is replaced. If you were not far off needing a new tyre then yes, probably an idea to replace the other one - but if you have a good amount of tread left, which it looks like you do, then there is simply no need to replace both. All you have to do is ensure that both tyres are of the same spec i.e. width/profile (and I think speed and load rating too) to be legal.
    HTH
  1. Nail in tyre woes!
    By SlowCoach in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2012, 13:32
  2. well thats the final nail in the coffin for the vec
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 27th October 2012, 09:14
  3. A nail took a chunk out my alloy
    By MCCABE in forum Suspension, Wheels & Brakes
    Last Post: 7th March 2011, 18:45
  4. nail in tyre question
    By ks246 in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2009, 13:17
  5. nail in tyre
    By andy.l in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2008, 09:49
