Results 1 to 10 of 13
Thread: Gearchange cable adjustment
    Default Gearchange cable adjustment
    I'm trying to adjust the cables on my F23 box, and a guy at vx said lift the gearstick cover and underneath theres 2 oblong boxes where the cables go in, thats how you adjust them, but how do you get the boxes open? I dont want to break them and i cant see which end opens up to allow me to get into the adjuster, help ta .
    Why have i been moved?
    a more appropriate section perhaps???....
    Ah, thank you
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Duncan put up a link for this on the F23, let me look for the thread.
    Vehicle : SRi
    Mileage : 137000
    Thanks Rushy, thats very helpful, unfortunately looks a bit of a pig, thought it might have been easier than that,
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    On the F23 to adjust the cables you put it in neutral and release the cables,on the gearstick housing you'll find a U shaped clip,place the gearstick in neutral and push the clip in,if it's won't go in it's not in neutral ,once the gearstick is locked do up the cables and thats it (according to my manual).After adjusting you could always fit a short shifter,feels a lot better than standard.
    Yep, i've looked at that, the u shaped clip is already in, and i cant see that just undoing the cables and putting them back in the same place is going to tighten the cables up. I thought by opening that little grey clamp there would be some positions to move the inner cable to, i'm a bit miffed ( normal for me ).
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    There's not a lot of adjustment,the end of the inner cable is ridged and thats what the fitting grips.Not a lot else to do except change the cables?.
  1. Renewing seat adjustment cable
    By Tigerfan in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2010, 18:55
  2. 1.8 Petrol SRI 2007 Throttle cable adjustment?
    By sduk in forum Petrol Engine related
    Last Post: 1st August 2008, 21:12
  3. F23 cable adjustment
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2007, 16:55
vectra c gear cable adjustment
