Results 1 to 10 of 17
Thread: Traction control switch
    addlestone ,surrey
    Default Traction control switch
    Dudes
    A few weeks ago I read a thread about fitting a traction control switch in a Signum.All I can rember is that if you find a blue plug thingie behind the blank you are green for go. Any chance of a reminder? and whats all this about tect2? My other car is a 35 year old landrover with 18 moving parts,none of which are electrical....so a simple explanation would be appreciated!
    Wes
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    Basically, if you've got a blue plug behind the blanking plate there is a chance
    the switch will work. There is no set pattern as to which engine sizes or models
    the switch works on, its just the luck of the draw.
    If the blue plug is there then the switch will still light up with the rest of the controls
    so it will fill a blank anyway.
    The easiest way is just buy the switch (£11 - £12) and give it a go.
    HTH.
    Jul 2006
    Mexico
    For the TC switch there is no more to cover than what Pricey said....good luck and hope it works for you....
    Not and expert on TECH2 but think I can describe it as the language for the ECU`s...please correct me if I`m wrong
    Tech2 is the vauxhall scan gtool for programming your car.. it also reads fault codes, resets airbag lights etc etc..but at £4.5K it's a bit dear for home use....
    addlestone ,surrey
    Dudes
    Cheers for the help,one more question will I need to get the traction control activated (assuming it works) or will it work straight off the bat?
    Wes
    Once the switch is in, it will either work or not work. No need for tech2, it really
    is that simple.
    Just seen your car is an '05', is it a facelift or a pre-facelift?
    addlestone ,surrey
    Dudes
    My car is a 2005 facelift reg no ##55###
    wes
    Last edited by Gsi3.2; 6th October 2007 at 18:28. Reason: don't post your numberplate..:-)
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    Sorry to tell you that unless your car has ESP (which is only fitted as standard to V6-engined cars) you won't have traction control as it only comes with ESP on the facelift Vectra. So a TC switch would do nothing, I afraid.
    apart from light up..
  1. traction control switch
    By neilshaw1980 in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2009, 09:45
  2. traction control switch
    By Beavis in forum Parts for sale
    Last Post: 13th April 2008, 08:15
