Thread: Have Vx finally admitted there's a fault with autobox and Radiator???
    Regular Member j13hdb's Avatar
    Nottingham
    Default Have Vx finally admitted there's a fault with autobox and Radiator???
    My car is currently at Vx for a 10 min recall job that after 2 hours I've had a courtesy car and come home
    I spoke to the mechanic just before I left to ask him to check my gearbox fluid isn't "strawberry milkshake" like and explained that a lot of us have had problems with a bung going and he said that he was replacing 2 bungs that are all to do with the said problem and in his words it's a bastrad of a job to swop them over! He's checked some pipes that go to the gearbox and it seems I'm ok!!!
    The only reason I knew of the recall was because GSI 3.2 told me about the bung going and after checking the Vx computer they found the recall so everyone with an auto get ringing Vx up and check for your recall!!! Hope this can save everyone a fortune
    if you have an autobox it's well worth a call..
    Brighton
    Does this affect all Autos. or just certain years?
    Mines an October 06, will that need to go in?
    nope, yours will be fine.. it's cars up to and around 2004 that need the attention i beleive.... they changed the design on the seals after that
    South London
    My car is a 2.2DTi with automatic box.
    What needs to be done to check if it is subject to a recall?
    More to the point how can I find out if it has the earlier seals?
    Replies much appreciated.
    just a call to your VX dealer to ask if your chassis number falls under any recall notices will suffice....they'll tell you if it needs any work done..
    Nottingham
    I've got the recall number- 06 12 16. I think if you ask for this it'll help and am sure someone on here can tell us exactly what it is!!!
  1. finally found a solution to the P1112 fault code :-)
    By Casper85 in forum Engine & Drivetrain
    Last Post: 7th December 2012, 14:00
  2. Intercooler radiator removal without water radiator
    By Whosane in forum Troubleshooting
    Last Post: 5th December 2012, 15:48
  3. what autobox do i have
    By jimmywhu in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2012, 07:42
  4. 3.2 autobox
    By poves in forum Engine & Drivetrain
    Last Post: 27th November 2008, 10:08
  5. autobox fault on 3.2 vectra elite
    By bryn in forum Engine & Drivetrain
    Last Post: 14th August 2008, 13:38
