Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Droning noise
    Jun 2007
    confused Droning noise
    I 've got a problem with my 3.2.
    Coming home from work last night there was an awful noise that I can only describe as a drooning type noise. Didn't notice it on the way in but the radio was turned up!
    It seems to really kick in when you get to about 40mph. Although I said drooning it might sound a bit strange but it sounds just like a dynamo (for those old enough to remember) almost like a driven noise if you get my drift.
    I thought it may have been the electric power steering pump but I am not so sure now. The steering works fine and there is no leakage.
    The noise is not there when stationary but once moving at 40mph+. The noise does change slightly with increased speed but depressing the clutch, freewheeling in neutral or even switching the engine/ignition off totally seem to have no effect.
    Any Ideas
    Mileage : 000
    Sure it is not from the gearbox, doe,s the noise disapear when you accelerate.
    It maybe transmitted from the road wheels through the gearbox hence no change when you press the clutch.
    Regular Member wardy's Avatar
    Chichester
    Is it from the rear?
    Could be uneven wear on the rear tyres. there have been several threads on that. Have a search.
    Jun 2007
    Quote Originally Posted by ed taylor View Post
    To be honest don't know if it's the gearbox or not. The noise does not diappear when you accelerate just changes pitch, less of a deep drone.
    Jun 2007
    Quote Originally Posted by wardy View Post
    Cheers for that, think I'll change the wheels round just to see. At least that doesn't cost to try ! begginning to think this is going to cost.
    Wheel bearing?
    Jan 2006
    Skynet HQ EMEC#5
    Big Phil also had a problem like that, his was down to tyres, see here:
    http://forum.vectra-c.com/showthread.php?t=27497
    if you want to drop by on the way home again HHH, i'll have a look for you if you like..
    Mileage : 000
    Yep It might be worth swapping the front tyres and put them on the rear. I was talking to a mate at work yesterday, He has a vectra too and he was told it was the rear wheel bearing,s But he got another mechanic to look at it and he said the bearings were ok, But the rear tyers had worn out of shape and showed him the distortion, that was making the drumming noise, must addmit I have not heard of it before, but not disputing the idea though.
    Regular Member badge25's Avatar
    Mar 2007
    west midlands
    Could be a wheel bearing! Does the noise change/disappear when you turn slightly left or right??
  1. Droning noise from the front offside
    By sheepish in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2011, 22:22
  2. drumming/droning noise
    By paulb70 in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 15:31
  3. rubbing noise/droning ?
    By bigmac in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2010, 10:54
  4. droning noise when reversing
    By Morephun in forum Suspension, Wheels & Brakes
    Last Post: 16th March 2009, 08:52
  5. droning sort of noise from back end?
    By monkeez in forum Vectra C / Signum Troubleshooting
    Last Post: 4th June 2008, 08:48
vectra c droning noise
