Thread: adjusting mirrors
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    Default adjusting mirrors
    when i adjust my driver side mirror the passenger side one moves aswell but when i adjust the passenger side mirror the driver side one dosent move, is my switch faulty ?
    cheers, Graeme.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    No, it's a 'feature' - you will also notice that moving the drivers mirror 'out' also moves the passenger mirror 'out' too.
    Supposed to save time as it adjusts both together and then you can fine tune the pass side
    Regular Member badge25's Avatar
    Mar 2007
    west midlands
    My car never used to do this. Both mirrors worked independently of each other until I had my exhaust fitted. Don't know why but got back in the car adjusted the mirror on the passenger side then the drivers and the passenger was miles out. totally miffed!!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Standard on Vectras and A Passat 130 TDI sport I had as well
    Mileage : 000
    No you do not have a problem, I discovered this phenomenon quite a while back, I belive the idea is so that if someone else drives the car they just adjust the drivers mirror and the pasengers will still be in the correct place.
    member of the smoke patrol 230bhp+
    take the battery off for a hour and see if all the ecu's reset
    Feb 2007
    Durham
    its a pain in the butt, your passenger side mirror may be in the correct position but the driver side mirror needs adjusting, so you adjust the driver side mirror and it also adjusts the passenger side mirror that was ok.
    Regular Member izonoky's Avatar
    Aug 2007
    London
    Quote Originally Posted by Gr4eme View Post
    Couldn't agree more. From the drivers seat the angles (of incident & reflection) are significantly different for each mirror. I thought this was an electrical fault too. When I rang the dealer, I was advised to book the car in for a check (?) I find the mirrors (compared to my previous car, Honda & our Verso) a tad on the small side, so adjusting them correctly is critical.
    I was in the Rotherithe tunnel when I first realised something was odd, imagine the fun I had trying to adjust them in that narrow space.
  1. Adjusting Handbreak
    By Alank in forum Suspension, Wheels & Brakes
    Last Post: 18th December 2011, 23:26
  2. adjusting lights
    By bigron1988 in forum Electrical & ICE (including SatNav)
    Last Post: 18th April 2009, 09:54
  3. headlights not adjusting ??
    By blackcountryroy in forum Electrical & ICE (including SatNav)
    Last Post: 28th December 2008, 21:00
  4. adjusting headlights
    By vectragsi3.2 in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2008, 20:29
  5. Boot adjusting
    By steve in forum Vectra C / Signum Car Chat
    Last Post: 4th April 2008, 20:16
