Results 1 to 10 of 20
Thread: Best lowering spring's
    Jan 2006
    Dalriada
    Default Best lowering spring's
    Looking to lower the car very soon so looking for advice on what are the best spring's on the market for the 2.0T??
    I dont really know much about this side of things so any advice would be good
    Regular Member Harry's Avatar
    Uxbridge, London
    i would recommend the Eibach Pro Kit springs, they're the same ones as Irmscher use in their kit.
    and you can a good price from Steve @ LMF - £145ish inc P&P
    [Ex]Admin Duncan's Avatar
    As above - can't really go wrong with those. Can't recall what spec yours is Steven, but if it hasn't got the SRi type suspension, I'd also look at changing the dampers too. Lowered springs on normal dampers isn't too great.
    Here, there and every where!
    I'd go for the Eibach's m8.
    Jan 2006
    Dalriada
    Cheers guy's - might give Steve a ring and see how much they will flog them for
    Jan 2006
    Dalriada
    Erm can anyone tell me the axel weight of the 2.0T - had a search but canny find anything and its dark outside
    Regular Member Madgunner's Avatar
    Worrying bout nothing..... Cause worryings a waste of my f***ing time!
    So uprated springs on sri's work fine with standard shocks then yea
    Jan 2006
    Dalriada
    SRi mate
    Quote Originally Posted by Steven View Post
    Just look on the plate on the driver's side B pillar - it's the line that has 1 - xxxx. xxxx being your front axle weight. Mine, from memory, is 1060kg. I think the Vectra would be the same for the front as a Signum, but I'd check.
    Quote Originally Posted by Madgunner View Post
    They should be okay.
    SRi mate
    Sorted then - just the springs really.
    Ex-Staff Full Member Taffyopel's Avatar
    Oct 2007
    Horley, Surrey
    I fitted PI springs to my 1.8 SRi. They were a 15mm drop being as the SRi's are dropped by 15mm as standard and are superb.
    The ride is still comfortable and handles like it's on rails.
    These guys were the cheapest and the service was excellent.
    http://www.potn.co.uk/p1253789.htm
    Hope this helps.
  1. Help with HID's and Lowering spring's fitting?
    By Henry42 in forum North East RO Vacant - ARO - Vacant
    Last Post: 10th December 2012, 14:23
  2. Which spring's
    By 150cdi in forum Handling & Braking
    Last Post: 27th November 2009, 22:19
  3. spring's question....
    By ANDY SHAD in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2009, 21:28
  4. recomend lowering spring's?
    By jungle in forum Handling & Braking
    Last Post: 7th May 2009, 21:16
