Results 1 to 3 of 3
Thread: Drivers Door Mirror
    Regular Member Bucko's Avatar
    Pudsey
    Default Drivers Door Mirror
    I have a Sept 2003 3.2 GSi and the drivers door mirror heater is not working. I am trying to get a replacement glass bit but VX don't seem to be able to find the right one. I have taken it off and had a look at the back and it has the normal two mini spade type connector on it for the power to the heating element, HOWEVER, this is not used. Instead ther is a little plug affair that is clipped into the back of the mirror and the wires from this go to soldered connections at the top and bottom of the mirror. Anyone else come accross this? It looks original, not something that someone has bodged together but none of the types that VX come up with have this pug thingy.
    Anyone any ideas??
    [Ex]Admin Duncan's Avatar
    You got a pic? The two little spades are what the wires should connect to for the heated part. Difficult to visualise what you're talking about without some pics.
    Pudsey
    Not got a pic as the engineer that took it off says he was lucky to get it of in one piece and then get it back on gain. Says they bear about 1 in 3 fitting them so have not tried to take it off again. The mirror has the two connectors at the end with long sticky out bit, but there is a little multiplug that is used instead. Will probably have to wait for it to come from GM in Germany. Just wondered if anyone else had seen this kind of setup??
  1. drivers door mirror
    By hippo in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2012, 14:29
  2. Drivers door mirror
    By stanian in forum Electrical & ICE (including SatNav)
    Last Post: 13th March 2011, 20:46
  3. Drivers electric door mirror
    By ben and ellies dad in forum Bodywork & Interior
    Last Post: 10th November 2008, 11:21
  4. Drivers door mirror
    By MalcGSI in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2007, 17:24
  5. Signum Drivers Door Mirror
    By signum3cdti in forum Vectra C / Signum Car Chat
    Last Post: 1st November 2006, 09:47
