Results 1 to 10 of 11
Thread: Lock wheel nuts : HELPPPPPPP!
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    Angry Lock wheel nuts : HELPPPPPPP!
    Not sure if any one can help, I went and had some new Dunlop tyres fitted to the wife's Astra last week,
    The garage over did it on the locking wheel nuts and FUC**D the the nut up (found out a few days later), I now have a set of bolts I can't get off the car , unless they chisel them off
    I've called a few dealers and they don't have the correct code (196) every thing but, I can order a new key @ £30 then I'll still have to get a new set of wheel nuts as one of the bolts is slightly out of shape,
    Does any one in the area have locking wheel nuts with a security code 196 I can use just to get the old set off or can one of the VX guys order me a set or find a set in the stores !
    Here, there and every where!
    I'd go back to the original garage that did the damage and get them to sort it out m8 Why should you have to pay for their mistakes
    Jul 2006
    Mexico
    As above....make them suffer....well.....make them to sort it out
    Oct 2006
    Portsmouth
    I'll be going in there Saturday, I have an nasty image of some greasy tool mashing the F*** out of the alloys with a chisel
    Feb 2007
    North west
    If the nuts are knackered just hammer on an imperial socket that is a realy tight fit then undo it. The nut will need throwing away but if you have to buy new ones anyway ??
    Regular Member Karl's Avatar
    Sunderland
    as above, bang an impact socket (black one) that is slightly too small onto the locking nut and they come off easily. Been forced to do this several times when I had no locking key.
    Oct 2006
    Portsmouth
    , cheers , i may try that 1st before the say good by to the alloys !
    what size is best ?
    Regular Member The-Bandit's Avatar
    Mar 2007
    snake hunting
    I too also had a similar incident but i lost the tool.......Its not as easy as knocking on a smaller socket because all that does is fits over the collet that goes around the locknut, if your lucky and i do mean lucky you can break the collet off then knock a smaller socket on whats left, if you know anyone who works for kwik-fit they have a special tool that can get them off, luckily for me they visit our bodyshop everday and all it cost me was a drink.
    Hope this helps.
    Feb 2007
    North west
    the size thats best is the one that fits - almost. It needs a hammer to persuede it on then its probably going to work.
    11 Post(s)
    Quote Originally Posted by markm View Post
    I thought the idea of these locking wheel bolts was that each set is unique and totally different to the next set.
  1. Lock Nuts
    By jamesmcuk in forum Engine & Drivetrain
    Last Post: 11th October 2012, 21:07
  2. Wheel Nuts
    By paulvectrac in forum Handling & Braking
    Last Post: 18th August 2011, 07:21
  3. wheel nuts
    By rickeys16v in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2010, 19:48
  4. wheel nuts help
    By surreyl31 in forum General Chat
    Last Post: 30th July 2007, 20:16
