Results 1 to 10 of 14
Thread: Reverse gear
    Regular Member Dave1.8's Avatar
    Oct 2007
    Ellesmere Port
    Default Reverse gear
    Hello Im new to this site. I have only had my car for about 2 weeks or so, but I find when I try to get reverse, there is a crunch from the gearbox. Its like Im not putting the cluch all the way down (but I am). My wifes Corsa C 1.2 dose it somtimes as well. If I put it in reverse slowly its ok. Has anyone else found this? Its a Vectra C Exclusiv 1.8 Face Lift. Thanks
    Mileage : 000
    Might sound daft but do you pull the ring type thing under the gear knob upwards when you engage the reverse gear. I remember a mate at work had this problem with a ford till I pointed this out to him, just a thought.
    Oct 2007
    Ellesmere Port
    Yes I do m8. It wouldnt go into reverse if I didnt
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    My neibours Corsa does the same and it ain't half loud !
    Makes me cringe every time i hear it !
    Mileage : 000
    Just a thought . I didn,t expect you to be as daft as not to know how to put it in reverse. I wonder if the clutch needs bleading[air in the system] or maybe the clutch is worn out has your motor done many miles.
    Mileage : 000
    Have you tried to double de-clutch before you put it in reverse. When my wife has difficulty geting her Vectra B in revers I tell her to try to double de-clutch it.
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    you might have to explain to the youngsters, what is double de-clutching. Unfortuately I'm old enough to know........
    Full Member Big Sig's Avatar
    Or put it into first before going for reverse.
    Oct 2007
    Ellesmere Port
    The car has done 40k. I bought it from a Lookers dealership about 2 weeks ago. Its just had its 40k service, and the network Q check. Its got 1 years manufactures warrenty left. Ill try doubling the clutch
    Remember, reverse has no syncro so it may well crunch a little when going from secone or third when stopped to reverse.
  1. Reverse gear problem after new clutch!
    By daniel9807 in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2012, 12:41
  2. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  3. Engaging reverse gear
    By julian924s in forum Engine & Drivetrain
    Last Post: 30th January 2011, 18:31
  4. my car struggles to engage in reverse gear
    By patdavis in forum Engine & Drivetrain
    Last Post: 29th October 2009, 19:37
  5. Reverse to 1st gear
    By MalcGSI in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2006, 04:07
vectra c reverse gear crunch
vectra c only revers gear
