Thread: How many times can megs clay be used?
    Regular Member Penfold's Avatar
    May 2007
    Sheffield
    Default How many times can megs clay be used?
    Hi
    As per title i got the megs clay kit when i got my car a few months ago and have used it once but i`m a little apprehensive about using it again because it seems a little hard.Is it supposed to be used more than once?
    Thanks Neal
    Strictly speaking only once. But I suppose it does depend on how dirty it is/was.
    [Ex]Admin Duncan's Avatar
    As long as you kept folding the dirty side into the clay, and only ever used one side, you can use it twice no sweat - as long as the clay isn't really manky. You just have to make sure you make a mark on the clay to identify which side you need to use next time.
    May 2007
    Sheffield
    Thanks for quick replys I ll have a look see whats its like ,if its cruddy i ll get another. £12 not too much to avoid scratchin the baby to bits.Thanks again
    Neal
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    hi guys, herd alot of people on here useing clay what is it and were can i get it from and does it relay make your cars that shinny. or do use anything before it is used
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    You can keep your old clay on a freezer back with a load of QD sprayed on it. But tbh I would only reuse it for wheels and maybe glass. If your not fully using the clay just cut some off at the start and keep that for next time.
    Glynn, you can get it from Halfords. You get two blocks of clay (so a years worth), some QD, a microfiber cloth and some cleaner polish.
    http://www.halfords.com/webapp/wcs/s...LL&x=813&y=102
    The clay picks up surface contaminants of the paint, you can then run your hand over the car and it will feel like glass, this will not only start to clean the paint but will prep it for polishing and wax. This pic shows how much crap it pulled of the roof of my star silver.
    The clay was white by the way!
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    I did mine a couple of days ago and only used half a bar. Always break it in half incase I drop the first bit. I did all the body work and windows with that half bar. Threw it away when finished. Other half is in the little case that comes with it.
    Aug 2007
    you may wish to also consider just buying the clay bar direct from on line suppliers. Try using the poly clays, they are much softer, and easier to use especially in colder months. You can also use the different grades, green is fine, yellow medium, and white coarse.
  1. megs clay bar
    By marc vectra sri in forum Detailing and Car Care Discussion
    Last Post: 13th October 2011, 20:38
  2. Megs clay, autoglym deep shine, megs gold class wax
    By bertbuckie1 in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2009, 23:51
  3. Megs Paint Cleaner and Clay
    By T4M in forum Detailing and Car Care Discussion
    Last Post: 22nd September 2007, 21:11
  4. Got me some Megs Clay today
    By David_SRi_2.2DTi in forum Detailing and Car Care Discussion
    Last Post: 19th September 2007, 10:26
  5. Okay, done the Megs clay and stage 1,2 and 3 - now what?
    By Duncan in forum Detailing and Car Care Discussion
    Last Post: 4th October 2006, 20:53
