Thread: cam rattle when cold start
    Regular Member sriturbo20's Avatar
    Feb 2007
    derby
    Default cam rattle when cold start
    i have a sri 20 turbo with a rattle on cold start up it lasts for about 5 10 seconds then goes had this problem before and the dealers replaced cam tensoiners and timing chain but now back again its booked in again on wednesday the rattle sounds like theres no oil getting to the top of the cam for that short time on cold start up any ideas welcome before wednesday as what it could b the cars a 55 plate
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Quote Originally Posted by sriturbo20 View Post
    Are you sure it's the cam chain that's rattling? Could it be the auxiliary belt with its pulley and tensioners that's causing the rattle? Is it a rattle or a 'twittering'? I've had my auxiliary belt and cam chain replaced so I know what a pain it can be. Mark (GSI 3.2) and Duncan are the experts; they were so helpful to me. All I can say is get it into the dealers and get them to sort it. There's quite a lot of stuff on here about this.
    Try this for starters
    Feb 2007
    derby
    diffo a rattle and had the chain and tensioner replaced in may
    Sound's like your hydraulic lifter's are draining of oil as long as the noise goes away after a few second's it will be alright try an oil and filter change with a flush put through first that may help !!!!
    Regular Member rickyroo's Avatar
    shropshire
    easiest way to know is check if their is any water on the bottom of your dipstick at cold, and also check your trottle body for oil their should be.
    Regular Member gazza1971's Avatar
    derby
    is it a new bi fuel vauxhall?
    sounds like the cam tensioner is draining of oil...if it's only on startup and doesn't reappear during driving, then it'll need to be looked at again ASAP..if it's while driving then it's new chain time..
    Feb 2007
    derby
    its had new chain and cam kit fitted in april this year ive just dropped it of at vx in derby so they can start when cold in mornin let you all know wot they say tomorrow
  1. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  2. rattle on start up
    By VEC-MAN in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2012, 22:16
  3. My rattle from cold now with fresh oil
    By Mark2.2 in forum Petrol Engine related
    Last Post: 4th April 2012, 21:49
  4. 1.8 VVTI Cold Rattle ..... Again
    By robdd1 in forum Engine & Drivetrain
    Last Post: 12th July 2011, 12:20
  5. rattle on start up
    By ant6566 in forum Engine & Drivetrain
    Last Post: 11th April 2010, 19:05
cold start chain cam rattle
