Thread: getting the sump plug out ????
    Apr 2006
    Quinton
    confused getting the sump plug out ????
    Hi,
    Does anyone have any tips for getting the sump plug out of mrs zx6r's astra g??
    I have now snapped three t40 bits in half trying to remove the damn thing, it just won't budge.
    Would an airgun quality bit and a breaker bar be a good idea and would it give any more strength before snapping than a normal cv t40 bit?
    Any tips gratefully received as I'm damned if i'm paying for the oil change after buying all the bits!
    Cheers guys
    Nick
    Have you tried gently heating up the area around the sump plug? not too hot - remember there is oil in there. If its that bad, supply the bits and get a garage to do it!
    Apr 2006
    Quinton
    cheers mate, i tried to loosen it after a good run so the sump was pretty warm then.
    I'm getting pretty sick of this car. Everything I come to do is met with a welded on nut or part of some description
    Nov 2005
    Sydney, Australia
    problem is with the torx key's - they are crap. Never have enough leverage , i had the same prob on my V6 . I just used a normal hex key which has a longer handle .
    you have to accept that it's goint to need a new sumpnut at worst, buy one in advance, then use the best fitting key you have avaliable and the longest bar, and just gently apply the force.. use an extension tube if you need to.. and it will let go..
  1. Sump plug
    By shb1988 in forum Engine & Drivetrain
    Last Post: 23rd August 2012, 18:37
  2. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  3. Sump plug
    By nokiaman1978 in forum Engine & Drivetrain
    Last Post: 8th May 2012, 20:46
  4. sump plug on my 2.2 sxi
    By smilerwas in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2010, 22:53
  5. Sump Plug Nut
    By si_hoss in forum Engine & Drivetrain
    Last Post: 22nd February 2010, 18:32
