Thread: Outside Temperature Guage
    Regular Member Del 2.2SRi's Avatar
    Scotland
    Default Outside Temperature Guage
    Tried a search but could not find any threads on this.
    How acurate is the outside temperature reading on the trip computer?
    The reason I ask is the other day I left for work at six in the morning, it was a bit chilly, windows all iced up. Got in the car and temp was 18.5 after the 15 minute journey to work the temp had only dropped to 10.5 even though it was still really cold outside.
    Other folk at work were seeing between -1 and 2 degrees on their temp guages. Is mine knackered? If so is it an easy fix?
    Cheers.
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    the temp gauge is only a few pounds. If it still gives inaccurate results you could change the gauge itself. You could check to see if its blocked with dirt etc...
    Scotland
    Where is the temp gauge located?
    Edit: Please excuse the spelling in original post, beer seems to affect my ability to type.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Its in the front bumper mate.
    Scotland
    Many thanks for the replies guys.
    I will have a look tomorrow when I sober up.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    it's between the radiator and the bumper. Open the bonnet and look down in the gap.
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Just being piccy...but the gauge is in the dash...the sensor is infront of the radiator behind the bumper...
    Check for dirt, corrosion or moisture at the connector / socket which could affect the resistance and therefore out put from the sensor...especially with such fine wiring..and also the exposed location...to the elements.
    You will need to change the sensor which is a plug in type replacement...not that cheap though...My cav 3 sensor cost about £12 a few years ago...
    The gauge / display will only be at fault if the corresponding driver or ecu is at fault...
    I know...there's always one gob-s***e...
    Sorry ...its my turn today.....
    Last edited by Robsey; 30th September 2007 at 13:57. Reason: incomplete response...
    Jun 2007
    in a white box
    Scotland
    Quote Originally Posted by Robsey View Post
    You are correct. Perhaps I would have been able to spell sensor.
    Had a look today, no sign of any dirt, corrosion etc on the sensor
    Think I will just replace it.
    Nice one. Cheers.
  1. Temperature Guage
    By garetmcc79 in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2012, 15:28
  2. temperature guage ?????????
    By VEC-MAN in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2011, 09:01
  3. Temperature guage
    By Martinlw in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2010, 23:40
  4. Temperature Guage - 05 CDTi 150
    By Gallen in forum Engine & Drivetrain
    Last Post: 15th November 2010, 12:28
  5. Fitting an oil temperature guage
    By Celes in forum Diesel Engine related
    Last Post: 25th November 2009, 18:51
