Thread: rear fog lights
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Smile rear fog lights
    Hi does anyone know if the wiring is in place to get the passenger side rear fog light working?
    Tyneside
    No m8 all you have to do is feed a wire from the drivers side across to the passengers side and then it'll work.
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    cheers
    11 Post(s)
    Quote Originally Posted by mark1319 View Post
    Won't this screw up the canbus, or at the very least confuse the bulb failure warning system ?
    Feb 2007
    North west
    no, done it on vectra & astra. Even the bulb is fitted, the earth is connected. Just needs a live from other bulb.
    Regular Member LJ sxi-nav's Avatar
    Winchester
    Feb 2007
    North west
    some bull arguments, its down to cost. If you want it working bung a wire from the working side across. How does anyone explain the up market cars that have 2 working rear fogs. I love all the references to "some kind of european driving law" lets see a copy and paste of this and i'll eat my words !
    11 Post(s)
    Quote Originally Posted by rob 2.2dti View Post
    It's not a european driving law. It's a directive. It is mandatory to have a rear fog light fitted on UK vehicles first used on or after 1 April 1980. This fog light is required to be fitted to the centre or offside of vehicles.
    A nearside foglight is optional and not a necessary requirement. Most car manufacturers realise this, and as you quite rightly say, some of it is down to cutting costs. The reason for having both a left and right fog light available in the Vectra light clusters is down to the fact that whichever country the car ends up in, the relevant fog light can be enabled / disabled; most likely with Tech2.
    That aside, I can't recall the last time I used either my front or rear foglights, so I'm not really fussed that only the offside one on the rear is operational.
    [Ex]Admin Duncan's Avatar
    Yep......
    4.11. Rear fog lamp 4.11.1. Presence
    Mandatory.
    4.11.2. Number
    One, a second being optional.
    4.11.3. Arrangement
    No individual specifications.
    4.11.4. Position 4.11.4.1. Width:
    If there is only one rear fog lamp it must be on the opposite side of the median longitudinal plane of the vehicle to the direction of traffic prescribed in the country of registration.
    In all cases the distance between the rear fog lamp and the stop lamp must be greater than 100 mm.
    I must admit, I had been lead to believe that it was some European safety thingy to only have the one. I guess it's been distorted as it's been passed on from person to person. As you say the European directive only requires one to be fitted, two is optional, so obviously some manufacturers decide to only do the minimum. Does seem mad though to have the cluster with the fog light in it, the bulb holder (deemed as a spare by Vx in the manual) and not just wire it up to have both working. All it would be is a bit of wire to enable it - they've done the 'expensive' bit with the cluster and bulb holder!
    Feb 2007
    North west
    thank god for that - for once im right - quick tell the wife !!
  1. Led Side Lights Fitted & 2 Rear Fog Lights
    By wardy23 in forum Electrical & ICE (including SatNav)
    Last Post: 12th March 2012, 23:16
  2. Dark lights and Rear Lexus lights finally fitted
    By Leviathan in forum Styling
    Last Post: 29th February 2008, 22:35
