Thread: Rear Windscreen Wiper
    SUFFOLK
    Default Rear Windscreen Wiper
    Does anybody else have issues with the rear windscreen wiper not cleaning the rear window effectively (tends to leave smears across the rear window). I've changed the blade and tried bending the arm a bit to increase the down force which has not made much difference.
    I've noticed from the new Vectra C Hire Cars the office keeps sending me that the later vectra Cs have a low profile rear windscreen wiper fitted to them. (04 vectra arm is much thicker). Any idea whether the later design is any better and can it be fitted in place of the older ones?
    Regular Member vectravirg's Avatar
    Bolton
    have the same problem with my 04, changed the wiper blade but still smears
    Sunny Dartmoor
    Never noticed.....
    Here, there and every where!
    Have you tried cleaning the blade with white vinegar? It cleans the grease from the blade.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    The rear screen is very flat so I bet there are loads of surface contaminants bonded to the glass. Even after washing they will still be there. Try claying the glass or polishing it with a good polish or a dedicated glass polish.
    SUFFOLK
    Haven't actually tried polishing the glass. Will give it a try.
    Cleaning blade with meths and replacing it for a new one didn't have much effect. Thats why I was wondering why vauxhall had changed the design.
    The later models have a different design m8, they can be fitted to the earlier models. Part number is in the "Parts" section.
    EDIT: Here you go.
    Rear flatblade wiper arm - 13143420
    Rear flatblade wiper blade - 13143421
    SUFFOLK
    Thanks.
    Will pick up a set in the morning. Can't be worse than the current one
    Feb 2006
    Dorset
    changing it for the later one will make sod all difference , mine smears , dont drive backwards that often anyway
  1. Windscreen wiper fault
    By Dibbly999 in forum Bodywork & Interior
    Last Post: 4th January 2011, 20:51
  2. single windscreen wiper?
    By rozza72 in forum Styling
    Last Post: 10th July 2009, 20:33
  3. Windscreen wiper dead
    By Nicolas in forum Suspension, Wheels & Brakes
    Last Post: 31st March 2009, 23:08
  4. Rear windscreen wiper
    Last Post: 19th May 2007, 16:50
