Results 1 to 10 of 14
Thread: How do I colour code my bumper spoilers & sideskirts????
    Regular Member skinnyman's Avatar
    manchester
    Post How do I colour code my bumper spoilers & sideskirts????
    Hi everyone
    I wanted to know if at all possible to colour code my black plastic front & rear bumper spoilers & side skirts???
    If at all poss, any info would help big!!!!
    Im also changing my sidelight repeaters from the standard orange lense to clear, are they stuck on or clip-on???
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    hi mate its not straight forward as you need to give them a good rub down and then degrease them so they are clean, then a good coat of plactic primer then a rub down and then primer before the top coat. most body shops are now useing water base paint so they can paint wet on wet
    manchester
    Hi, thanks for that m8. Can u buy the paint in a spray can, if so would it be the dealers??? Also do you rub down to make smooth surface?? matt
    depends on the finish you want if you want a nice smoth finish then give it a good rubb down till smooth amd the paint can be brought i a can to match for car coulor. you could buy it from a body shop factor i.e ar davies, avenue panel. if you have these sort of named factors your way.
    manchester
    Thats great im going to give it a go. Did u mean u can match the paint??
    I think I know somewhere that sells paint.
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    To save a lot of grief I would approach a bodyshop or two to get some quotes to get it done properly - it might not cost as much as you'd think.
    Are those bit removeable? If so then it may be even cheaper as the bodyshop can do them at their leisure if you get my drift.
    the parts can be removed as i have done mine. but the paint can be quiet dear if they use water base
    manchester
    I think ill ring get some prices, but quite fancy a challange...... The info is great by the way. ta
    Jan 2006
    Skynet HQ EMEC#5
    I got mine done at a local bodyshop near work, see this thread:
    Side skirts, rear valance & 4 mudguards £150
    http://forum.vectra-c.com/showthread.php?t=10601
    anywhere
    Side repeaters are clip in and slide out.
    Buy the clear 1s from VXL dealer as they are under 4 quid each n use the original bulbs.
  1. dont buy these bumper spoilers off eBay .....
    By Steven T Davies-Moss in forum Styling
    Last Post: 13th October 2011, 23:19
  2. front bumper spoilers
    By leonvectrac in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2009, 20:15
