Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: No more!
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Default No more!
    I've spent too much time and money, ignored my lovely and gotten very stressed at points, all just to get ready for this weekend.
    NO MORE!
    That's it, I've finished now and what is sitting out there now is what will be there this weekend.
    Well maybe just another tweek of the filters.
    Anyway, here's a little list of what mods I'll be sporting for the rolling road on Saturday...
    1) rear scilencer removed
    2) turbo down pipe de-restricted (pre-cat removed)
    3) custom airbox with two cold air feeds, sporting TWO foam air filters
    4) twin intercoolers in series (standard one and the biggest FMIC that would fit, infact it doesn't fit properly it's so big)
    5) Tuning box obviously
    6) Turbo overboost spiker, running upto 32PSI (That's what I'm calling my one way restrictor )
    7) de-restricted upper front grill with extra air feed slot
    8) and finally, some insulative lagging of air pipes
    So as I said to spoons yeasterday, "it's on like Donkey Kong!". I wasn't sure I was going to have a car to drive at all at one point yeasterday but I went to plan 'B', cut some bits up, got them welded today and it's all good again!
    One problem though, I did notice a touch of clutch slip earlier... Might have to tune it down a fraction for the rollers to be sure of avoiding this.
    spoons
    Guest
    Right....
    I'll be ready for Saturdays rolling road....
    Sporting....
    - 888 Stage II remap with added Turbo Boost & Fuel Pressure
    - K&N Panel Filter
    - De-restricted the Airbox
    - Cut out a cold air feed
    - De-restricted top grill
    - Fitted 26" Bar & Plate FMIC (InterCooler)
    - 2.5" Turbo Downpipe
    - Straight through exhaust (sounds like a V6 !!) - No Pre-Cat, No-Main Cat, Straight through mid box, no back boxes !!
    - and.... and..... Heat Wrapped the Turbo Downpipe as seen below....
    Cant think of anything else now....
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Hmmm, might have to drop my exhaust off from the turbo down pipe for the RR...
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by spoons View Post
    Right....
    I was going to ask if anyone had done this. Have/are you going to do the manifold also? Nice little touch by the way.
    Full Member Big Sig's Avatar
    Quote Originally Posted by nutron View Post
    Don't diesels need the back pressure from the exhaust for the torque like a petrol?
    spoons
    Guest
    Cheers, should do the job nicely.... It also makes the exhaust note a bit more muffled.... in a sort of 'burbling' sort of way....
    I'll do the manifold another day... when I replace the heat guard !!
    Regular Member Silver V's Avatar
    Jul 2006
    mmmmmmmmmmmm
    this is what i keep gettin told!!
    spoons
    Guest
    Back pressure is very important as it provides torque !!
    So what is the gain for nutron removing the exhaust from the turbo downpipe apart from loosing torque?
    Vehicle : SRi
    Mileage : 137000
    Higher bhp lower torque I think.
