Thread: Hardwire GPS?
    Regular Member maz's Avatar
    Lincoln
    Default Hardwire GPS?
    Right people. Trying to hardwire my GPS navigation and Snooper into the cars system to allow power when turning on the key. Obvious way is through the cigarette lighter or through the fuse box. I can do the job but anyone know of a step by step guide on the net to help?
    Lincoln
    Never thought of buying a seperate multi fag socket from "hellfrauds" (good choice of word) and hiding behind the dash. Would mean i could plug the two in and solve both problems. Where bouts did you find the cable for instument/heater lights. Just gotta learn how to get to the certin wires to scotch lock in. They seem to build these cars to last nowadays. Had thought bought the fag socket if i can get behind it, after all, all i need is an ignition controlled live, earth isn't the problem.
    How you getting on with the prblem of thieving s****? Take it there is no comeback at the mo?
    Regular Member Damian's Avatar
    Market Drayton
    Do you find you find you get some interference with the radio in having the fag lighter extension behind the dash.
    I have a 3 way one sat behind the heater controls. When I switch the radio on the signal (to Radio 1 only bizarrely) is fine. As soon as I switch on the ignition the signal becomes fuzzy (Again only on Radio 1) and the radio struggles to retune to find a good signal
    Have though about wrapping the extension socket in tin foil
    Damian
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The foil would have to be earthed to ensure good screening.
    tomorrows Sun Headline:-
    'BACOFOIL SALES DOUBLE'
    Lincoln
    Posibility could be that it is to close to the aerial lead. Strange that it would be only radio one though. Unless its the frequency? Have you tried moving the fag extension to another part of the car/somewhere else behind the dash?
    Market Drayton
    Quote Originally Posted by maz
    I haven't yet no. But like I say it only happens when the ignition is on so hence the fag extension is live
    Lincoln
    That would be my guess then, the power of the extension is affecting the radio signal through the wire. I'm gonna have a shot at it today so i'll let you know how i get on with mine. If i test it behind the heater controls too.
  1. Hardwire
    By Dave1.8 in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2008, 23:06
  2. How do you hardwire the other rear fog light.
    By Ross DTi 2.2 in forum Styling
    Last Post: 21st September 2006, 07:08
