Results 1 to 10 of 11
Thread: stereo is staying on!
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    Default stereo is staying on!
    quick question ,my new motors cd30 (with bluetooth) doesnt come on with ignition and when you turn engine off it stays on can i sort this myself or is it faulty HU? any advice mateys?
    Tyneside
    I know my m8's dose the same and I thought it might be a fault, but he said it has always done that.
    morton
    lovely SRI matey ! not sure what your prob is !!
    Regular Member rosssri's Avatar
    S.Lanarkshire
    If you go into the audio settings i think it will be under IGN. LOGIC try switching it on if it is marked off or vice versa. I can't remember which way about it is, but this switches your stereo on when ignition is switched on and also switches the stereo off when ignition is switched off and keys removed.
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Quote Originally Posted by rosssri View Post
    If you go into the audio settings i think it will be under IGN. LOGIC try switching it on if it is marked off or vice versa. I can't remember which way about it is, but this switches your stereo on when ignition is switched on and also switches the stereo off when ignition is switched off.
    cheers ross mate ill give it a go
    morton
    mine only goes off when i remove the keys !
    Tyneside
    Quote Originally Posted by veccy22 View Post
    As mine does, but its a cdr2005
    S.Lanarkshire
    Quote Originally Posted by mark1319 View Post
    I ment to add that to above post - now been sorted.
    Oct 2006
    Waterloo, Liverpool
    8 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    To prevent battery drain the radio goes off after one hour if it is left on after the keys have been removed. VX have had that in their cars for some time. Similarly if the interior light(s) is(are) left on, they go out after 20 minutes.
    S.Lanarkshire
    If you press the SETTINGS button , Audio will appear.
    Press the down button on stereo/radio control, SYSTEM will appear.
    Now press the right button untill Ign Logic ON or OFF appears
    Press the down or up button when Ign Logic ON or OFF appears
    You want it to be switched ON if you want the stereo to switch itself on when you put you're key in the ignition and then turn itself off when you take your key out of the ignition.
    Finally press the SETTINGS button to exit the menu.
  1. Calling ICE/stereo experts.. Dvd/stereo, will this fit in my Pre-face Vec C Gsi?
    By TAB in forum Electrical & ICE (including SatNav)
    Last Post: 27th February 2013, 13:20
  2. Sorry all, looks like im staying here :)
    By Mads in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2012, 11:16
  3. Looks like I'm staying!!!
    By luke4487 in forum General Motoring Chat
    Last Post: 6th April 2012, 19:43
  4. Fan staying on
    By chills in forum Diesel Engine related
    Last Post: 4th December 2011, 21:48
  5. Factory fit stereo to ordinary size stereo
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2007, 12:24
