Results 1 to 10 of 25
Thread: How Does Your Car Run When The Dpf Is Cleaning
    Regular Member mushy2007's Avatar
    Liverpool
    Exclamation How Does Your Car Run When The Dpf Is Cleaning
    Hello All,
    I have noticed when the DPF is cleaning idleing consumption goes up to .8/9 from .1 and runs rough as a tractor.
    When driving though it is like a rocket ship
    Anyone else have the same issues?
    Regular Member archerz's Avatar
    May 2007
    Teesside
    Engine : 3.0 v6 CDTI
    Mileage : 57500
    not even noticed when mines come on?! i have an 56 estate and never seen any dash lights come on to say anything was happening and i've covered nearly 24k in it...
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Quote Originally Posted by archerz View Post
    me as well. never seen it come on.
    Regular Member shadow's Avatar
    Mar 2007
    Rotherham
    Does a light come on ? I have never noticed any signs that its running whilst driving along.
    A few weeks ago whilst warming the car up after our holidays, There seemed to be a strange smell from the exhaust, Could this be the DPF cleaning its self.
    Regular Member vectravirg's Avatar
    Bolton
    I've never noticed anything either, are there certain veccys/signums that don't have a dpf? my understanding is its the more recent models.
    On a Sabbatical daviek's Avatar
    ayrshire scotland
    Only had my signum for 5 days how often does this occur and how do you know when its doing it
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    Quote Originally Posted by daviek View Post
    You don't know it is doing it unless you look carefully. The light on the dash doesn't come on. Apparently that is for the european market not UK and I thought we were meant to be in Europe. Vx say you should not notice the DPF coming on.
    Ok, DPF can come on at any point and the only way you would know is by the instaneous consumption value. The engine about 1 second before(this is on the V6 not 1.9) cuts in should give a very slight burst on the rev counter (about 200 revs)and you'll only notice it if you are aware of it. The 1.9 went through a recall recently(not all of them) for the DPF re-programing. They changed the programme to every 30 seconds I belive.
    I am told the DPF should cut in at 80% but I can't get anyone at Vx to confirm this. If you are cruising and you instant mpg is 38 then as the DPF cuts in this would drop to 22ish until the regen is finished. The DPF has to heat up to 700C as a minimum to go through the regen stage so in order to do this, it increases the fuel and burns it to achive the temperature down at the CAT I think. If you were idle the consumption would be about 1.0. You can't always drive at speeed when it is on but it is advised that you do drive around 60ish.
    DPF can cut in anywhere between 200 & 2000 miles depending on a large number of factors, fuel driving style etc.
    I think mine is faulty(on my second one) as mine regens at 400 miles and lasts for 8 miles(motorway driving) and can almost set my clock by it. Vx deny they have changed the programming of the DPF but my last ECU update came direct from Japan(Izuzu). But who cares because about this one because Vx are gonna buy the car back.
    Quote Originally Posted by mushy2007 View Post
    Driving when the DPF is on should be sluggish/less responsive to the right foot.
    May 2007
    Teesside
    Mileage : 57500
    i have noticed later on at night when i'm booting it i get smoke out the back, i assume this is when it's clearing.
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    Quote Originally Posted by willc01 View Post
    I actually find mine to be like Mushy says ... when the DPF is regenerating it makes the car feel more responsive and the turbo sounds much louder ... the turbo seems to spool up very quickly (I suspect the turbo is already running a low RPM before I depress the throttle). I've often thought I wish I could get the DPF to run manually for the odd time you want the car to be more responsive (like a sport button ... certainly uses enough diesel for it to be in sport mode! )
    Jul 2006
    Cheshire
    you shouldn't get any smoke out of a DPF 'enabled' car ... when it's cleaning it does so by heating the DPF to around 600 degrees c which makes the particles 'evaporate'. I suspect you perhaps don't have a DPF but do have a right foot that weighs heavier at night?
  1. Cleaning egr
    By morrisseyno1 in forum Vectra C / Signum Troubleshooting
    Last Post: 4th September 2011, 20:16
  2. egr cleaning
    By hbomb in forum Engine & Drivetrain
    Last Post: 8th July 2011, 18:00
  3. cleaning help
    By davidlewis24 in forum Detailing and Car Care Discussion
    Last Post: 13th April 2009, 20:37
  4. DPF Cleaning?
    By parapaul in forum Diesel Engine related
    Last Post: 9th October 2007, 13:52
  5. Cleaning
    By thegoldenbullet in forum Detailing and Car Care Discussion
    Last Post: 11th August 2007, 22:13
