Thread: Rear View Mirror - what is this bit....??
    Oct 2006
    Yorkshire
    confused Rear View Mirror - what is this bit....??
    ....on the non mirror side of my rear view mirror, i.e the part of the mirror that faces towards the bonnet, there is a hole with some sort of sensor?! in it. Any ideas what it does?
    Regular Member Harry's Avatar
    Uxbridge, London
    i think it's used for two things. it measures the ambient light outside so that the self dimming mirror can function, and also uses that ambient light reading to switch on the little light bulb at the base of the rear view mirror. i think that's right anyway.
    Oct 2006
    Yorkshire
    Default mirror
    Hmmm thanks Harry
    Uxbridge, London
    Quote Originally Posted by bennyk View Post
    Hmmm...
    what's the Hmmm for? are you not convinced?
    Full Member Big Sig's Avatar
    Is it not for the auto lights too if fitted?
    Uxbridge, London
    Quote Originally Posted by Astrase20 View Post
    yep...i think it would be used for that too.
    Regular Member denzo's Avatar
    Runcorn
    No, the auto lights function has a sensor on the dash board .... i think
    Quote Originally Posted by denzo View Post
    That little lump on the centre of the dash is for the climate control.... could be another sensor there too though.... anyone know for sure
    Oct 2006
    Waterloo, Liverpool
    10 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Quote Originally Posted by Harry View Post
    The little light bulb you refer to is called 'indirect night lighting' which shines on the centre console and gearstick area, when it is dark. You can test this in the daytime by covering the sensor with your fingertip before switching on the ignition, and it should illuminate and remain so until the ignition is switched off. Standard on all pre-facelift except for LS/Life, Expression and Club trims. Not sure about facelifts though.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    No, the sensor for auto lights is on the windscreen, same place as rainsensor
  1. Rear View Mirror Blocks all View to Left
    By bren in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2008, 21:36
  2. Rear View mirror
    By 2.2DTISRI in forum Vectra C / Signum Troubleshooting
    Last Post: 6th March 2008, 13:03
  3. Rear view mirror
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2007, 14:00
  4. Rear view mirror
    Last Post: 19th November 2007, 23:02
