Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Snow Foam..
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    Default Snow Foam..
    got a halfords hp125 pressure washer, with built in detergeant tank...cant post link up cos i cant get on halfords site..
    just wondering whether i would be able to use the snow foam stuff with it or do i need a karcher or somethin similar with the ickle bottle??
    [Ex]Admin Duncan's Avatar
    You need a proper foam attachment of some sort - the built-in detergent one on the Karcher simply doesn't give the effect you'll be after. Karcher do a small foam attachment which works not too badly, and it's a helluva lot cheaper than the fancier ones out there.
    Have a look on ebay etc. as the normal retail price for this is IMO a bit steep. I got mine through a guy on Detailing World for something daft like £6 = P&P, so might be worth a look over there.
    HTH
    don`t put it through the pressure washer, you could burn out the motor as it will foam up inside and the motor will not have the resistance it needs. I got mine from c&s , it is a great toy, I mean tool and you don`t need to touch the car, great stuff !!
    hmmm...would I be able to just change the lance for the bottle attatchment...dunno what size i need...will see if the handbook says out!...
    I want snow!!!!!
    what do u mean u dont have touch car...?..hows this stuff work..do u rinse first then snow foam it then rinse again then wash as normal?...i just want snow cos it looks cool..lol
    Regular Member Harry's Avatar
    Uxbridge, London
    what tommy is talking about is a contact-less wash, which is what we should all aim for as it negates the need for any scrubbing, which is where potential for scratches and swirls is introduced.
    with the snow foam you apply it to a dry car, it'll 'cling' to the car longer that way, whereas with a wet car it'll slip off quicker. leave the snow foam to loosen the dirt and grime for a few minutes and then pressure washer off. providing that the car is only lightly dirty you should be left with a squeky clean car...in theory, hence no need for a wash mitt.
    NOTE: i've never been able to get away with this, maybe because i only use snow foam through a gilmour and not a foam lance (been toying with the idea of getting one).
    Regular Member Happy Dave's Avatar
    Nr Blackpool
    the Karcher bottle attachment doesnt fit onto the halfords lance, I got one to try and it was a different fit, I couldnt do it with any of the adaptors I had either. I got the bottle from Halfords for a tenner
    Uxbridge, London
    if you're after a 'proper' foam lance for your pressure washer then i'm sure autobrite do a large enough selection of attachments
    http://www.autobritedirect.co.uk/sho...sort=2a&page=2
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Or a cheaper option is a 'superspray' not as much snow as Autobrite but it's only a tenner on ebay and doesn't do a bad job.The trick is to keep the car fairly clean,that way it takes less time and less products when you have to wash it.
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    Any one used this with the SS ?
    Its the Karcher Foam Lance !
    Oct 2006
    Portsmouth
    Quote Originally Posted by markm View Post
    I've just picked one up at lunch time, I'll let you know whats its like, if its no good I'll take it back "As it doesn't fit my Karcher"
  1. snow foam
    By ben2996 in forum Detailing and Car Care Discussion
    Last Post: 30th December 2010, 22:02
  2. Snow foamer and snow foam....
    By david.aka.judas in forum General items for sale
    Last Post: 11th April 2010, 22:27
  3. Snow foam
    By padre9390 in forum Detailing and Car Care Discussion
    Last Post: 4th August 2009, 20:16
  4. Snow foam
    By Steven Bee in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2009, 00:13
