Results 1 to 3 of 3
Thread: Check 3rd Centre Brake Light
    Hamilton, New Zealand
    Default Check 3rd Centre Brake Light
    We are occasionally getting the warning check centre brake light, this will some times come on when starting the car (foot on brake pedal!), when checking the centre rear brake light sometimes one or two or more of the LED's are not working, then it seems to fix its self and they all will work, then other times different LED's will not work and they ones that were not working before are working. Has any one had this problem and is there a solution? The dealers here have said the whole unit, needs to be replaced at a high cost, i wonder if it could be a poor connection some where, or possibly a voltage thing, dry solders, that could be easily fixed, any ideas? Thanks
    if you remove the boot hatch cover , you'll be able to get to the elctrical connector of the lamp unit to see if any joints are corroded..you'll also be able to release the lamp unit from the holder as well for a closer look..
    the boot liner is only fitted on with plastic fittings and a few screws.. it's not hard to take off yourself..
    Jul 2006
    Mexico
    Sounds like a faulty electrical connection....or the brake light it`s about to die....play with the electrical plug and check is making good contact all around
  1. Check Right Brake Light
    By Dobs in forum Engine & Drivetrain
    Last Post: 20th October 2012, 09:13
  2. Check Brake Light
    By gavmckay in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2012, 11:15
  3. Centre Brake Light
    By WilliamLX in forum Insignia car chat
    Last Post: 27th September 2010, 14:48
  4. Brake Light Check
    By tangoman in forum Electrical & ICE (including SatNav)
    Last Post: 18th October 2009, 22:11
  5. Centre Brake light
    By Karin B in forum Bodywork & Interior
    Last Post: 5th September 2007, 12:41
