Results 1 to 10 of 15
Thread: 1.9 CDTi Clutches...
    spoons
    Guest
    Default 1.9 CDTi Clutches...
    Does anyone know anything about 1.9 CDTi Clutches...
    - How much do they cost
    - Are they easy to fit
    - Can they be replaced by a competition (more stronger version) clutch
    etc etc etc...
    P.S. .... only asking so I'm prepared.....
    Here, there and every where!
    They are not cheap and are a pig to fit so i'm told, all nearside subframe has to come off. 5-6 hour job It might be longer due to the DMF. Don't think there is a performance clutch out there yet. There wasn't for my Saab Aero a couple of months ago.
    Regular Member cameraman's Avatar
    Leicester
    I've a feeeling mine might not last the distance either, not had a clutch replaced since 1987 in a Maestro Van!!, but adding loads more power is having a detrimental effect on the clutch (& the brakes)
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    The box is more than likely used in other GM cars over the pond. Try looking there as there are sure to be more avenues over there.
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    Slips on the racetrack at all?
    Clutch is a worry.. not sure it's up to the job of 300+ lbft :/
    Mine is rattling on tickover a bit now, not sure if it's a problem, but didn't notice it before.
    Jan 2006
    Skynet HQ EMEC#5
    Quote Originally Posted by Caterman View Post
    Why don't they keep it like the astra's & cavalier's used to be, I think they could be changed in under an hour
    spoons
    Guest
    Quote Originally Posted by Hideous View Post
    Yep,
    Third lap of the Nurburgring the clutch started slipping...
    Third traffic light on the Walsall Ring and I think I noticed a bit of slip as I pulled away using the ASBO technique..
    This car must be pulling around 300 lbft now... or more... and I still want to stick more power in...
    spoons
    Guest
    Quote Originally Posted by bailes1992 View Post
    Have you thought about using the clutch from the Saab 9-3 1.9 TTiD? I mean that things runs 180bhp?
    I wouldnt touch anything that had the letters 'AA' right in the middle of it.
    morton
    if you've done one before !? its a 3 hour job ! the sub frame needs to be droped , if its DMF ? you need a big bar and some thread lock to put the flywheel back on ! and try not to damage the slave cylinder as they are over £60 ! when mine went , i bought an uprated flywheel n clutch from courtenay ! which as it turned out does'nt fit the C (2.2 petrol) ! both courtenay and regal did'nt know this !! any more info you need ?? drop me a line matey !
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    The clutch alone is about £450 cos I looked at getting an uprated one when my old one starting slipping (wasn't slipping when it went to 888 but it was when they gave it back...) but no body does an uprated clutch so it would have to be custom made and they will need a 1.9CDTI clutch to work from.
  1. Are the flywheels/clutches the same in all 2.0 dti vec C
    By cobology in forum Engine & Drivetrain
    Last Post: 8th February 2013, 19:55
  2. Anyone know anybody near me good with clutches?
    By Alank in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2012, 13:17
  3. How is the Vectra 1.9 CDTi 150 BHP on clutches and gearboxes?
    By firebits in forum Engine & Drivetrain
    Last Post: 21st March 2012, 09:37
  4. whos cheapest for DMF and clutches
    By Xpolicevectra in forum Engine & Drivetrain
    Last Post: 5th January 2010, 13:06
  5. Astra Clutches
    By CHRISSMART41 in forum Engine & Drivetrain
    Last Post: 31st October 2007, 20:25
