Thread: Steering wheel warning light?
    Regular Member vectravirg's Avatar
    Bolton
    Default Steering wheel warning light?
    Got in the car tonight after it being parked up for 10 mins, went to reverse out of a parking space and steering felt incredibly heavy, noticed a warning light on the dash - yellow steering wheel symbol with an exlamation mark.
    Turned car off and re-started everything seemed fine, wondered if its the power steering fluid?
    Anyone else had this or know what it is?
    Jan 2006
    Hornchurch
    low battery power ?
    it's the CIM module just having a 'moment', as long as it doesn't come back on again then you'll be fine... if it reappears, drop it into VX..
    Bolton
    Whats the CIM module?
    Column Information Module...
    it's a canbus node that carries all the wiper/indicator stalk/ignition switch/steering angle sensor information
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    i had the same light on on my vec last week because i disconnected the loom from the bat to the pump as i was waiting for second hand pump and loom to arrive fitted them on saturday a all is good
    Bolton
    Cheers Mark, hopefully its nothing and just a glitch as you mentioned.
    Feb 2006
    Guttedsville
    It's called a terminal 15 startup failure. (honest, I'm not joking this time)
    Basically, the car being started sends power to a series of different ECU's, if you move the wheel before the car is 'properly' started and ready, this can cause it.
    There are also instances where the ECU's can be a bit slow to wake up, which also causes it.
    Apr 2009
    izmir
    I have this problem ı dont know ?
    help me please?
    how much CIM module?
    Apr 2009
    izmir
    ı have esp light and servo steering warning light .
    autorotihy said me the CIM sensor must be change !!
    it price 500 euro !
    is it normal price ?
    thanks alll ...
  1. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  2. Help - Steering wheel warning sign??
    By mishima in forum Engine & Drivetrain
    Last Post: 19th February 2011, 13:59
  3. Steering wheel warning light
    By ColinB in forum Electrical & ICE (including SatNav)
    Last Post: 8th February 2010, 21:20
  4. Steering wheel warning light
    By mooj in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2007, 10:00
  5. warning light,unable to turn steering wheel
    By steve.o in forum Suspension, Wheels & Brakes
    Last Post: 20th March 2007, 20:35
vectra c cim module esp light www.vectra-c.com
