Results 1 to 10 of 24
Thread: V6 Coolant
    Regular Member aaruck's Avatar
    Cheshire
    Vehicle : Insignia
    Default V6 Coolant
    Morning all,
    ON hardish acceleration I find that the coolant logo flashes up. It then goes off when the car settles. I assume this means that its a little low. Can anyone tell me what type of coolant I need? I saw somewhere that someone put water in to top it up; is this ok?
    DERRY
    also wanting to know the answer to this myself....
    not too much water.. ideally a mix of water and the red longlife antifreeze should be used..Don't be tempted to add blue antifreeze to the car thou..
    Cheshire
    Vehicle : Insignia
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    make sure u top it up when the car is cold
    Jul 2006
    Mexico
    By "top it up" I guess you don`t mean to to fill the hole thing right? Just to the middle, where the arrow it`s at right?
    i hope so...the coolant needs room for expansion, thats why they put the level to fill to 1/2 way up..
    Tyneside
    Why not blue antifreeze, its not going to do any damage.
    it's not reccomended to mix them, thats all...if it's filled with red ( longlife 5yr ) then top it up with red..if it's been changed to blue ( 3yrs with less corrosion inhibitors) then top it up with blue..
    standard practice is never to mix them..
    Tyneside
    Alright get you now, thought you ment don't use blue at all.
  1. Coolant
    By tubby in forum Engine & Drivetrain
    Last Post: 16th November 2012, 21:36
  2. which coolant ??
    By VecPower in forum Engine & Drivetrain
    Last Post: 30th October 2010, 18:04
  3. Coolant Top Up
    By alembicbassman in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2010, 15:54
  4. Coolant
    By Bloicy 3.2 V6 GSI in forum Engine & Drivetrain
    Last Post: 23rd August 2009, 12:19
  5. Oil in Coolant!!!!!!!!!!!
    By mipai in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2009, 14:43
