Results 1 to 10 of 11
Thread: Air in system 2.2dti
    derbyshire
    Default Air in system 2.2dti
    hi all -
    i used to have a 2.2dti omega, if i left it for more than a few days it refused to start.
    anyhow someone told me that on those engines air can enter the system from the fuel return pipes.
    any how my mate has seen a cracking 2004 reg vectra 2.2dti with similar problems.
    is it possible that a fuel injector could be letting in air, and is there any way to check this out.
    are injectors difficult to replace.
    cheers
    it sounds like a classic case of air entering via the injector leak off pipes..the rubber gets brittle and fractures allowing in air..
    dead cheap, and dead easy to change..you don't need to remove the injectors etc at all..
    derbyshire
    the current owner says he doesnt know why it has problems starting, are the injector seals easy to do.
    it's not the seals.. it's small rubber leak off pipes..
    derbyshire
    if you had the choice would you go for a diesel or a petrol.
    i have a td4 freelander and its been brill, but i do like the 3.2 vectra. getting on a bit now so i can afford the insurance. what do you get mpg wise i do mainly mway driving and how about reliability, does it have as many issues as the smaller engined vectras
    reliability has been 100% on it.. in fact i don't quickly recall any of us 3.2 owners ever having a serious issue with our cars..
    realisitic MPG is a combined 20 in my auto ( but i do drive it hard) and manuals should give you around 26MPG..on a run it'll give up to 30 but no more..
    I'm totally Biased..we have two 3.2's here.. (mine and the wifes) and the 150 CDTi that my father owns has been a dog..so i'm not looking to diesel any time soon..
    derbyshire
    hi
    is there a fuel pump in the tank, my mate has rang the owner and he said he was advised by his garage that it needed replacing
    morton
    mark ! he aint listening to you !!
    yep.. i get that feeling....
    if it just is a swine to start after leaving it overnight, just look at changing the injector leak off pipes..
    Full Member Big Sig's Avatar
    Yep listen to mark - GSI3.2. Get the leak off pipes changed!!!!! That is 99% what it will be.
  1. DTUK multimap power system and red power system - opinions please :D
    By Princess D in forum Diesel Engine related
    Last Post: 13th December 2010, 01:03
  2. 2dti vec b
    By SRimonkey in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 20:01
  3. GSi Exhaust System onto 2.2DTI
    By damian s in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2010, 17:57
  4. Best MPG from a 2.2DTi??
    By BigMan in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2008, 09:40
