Results 1 to 10 of 11
Thread: Side Repeater Replacement
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Default Side Repeater Replacement
    Hi all, can anyone help me as on how to remove the side repeaters from the car?
    I can not find anything in the manual and i have tried to slide them towards the front and rear of the car but no joy.
    Would be most grateful for any help, advice or pages to look at in the manual.
    Gazza4
    Regular Member Elite2.2DTi's Avatar
    Jul 2006
    Southampton
    mine came out really easy, just put something flat on the side and popped it off.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Generally worried i will rip the whole thing off the wing.
    Does it slide off?
    Gazza4
    Jan 2006
    Hornchurch
    just push them a bit harder they have a small clip on them
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    What way do i push - towards the rear?
    Gazza4
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    the best thing is to lift them where the point at the front of the indicator is and then it unclips. this is what i did when i replaced mine about a week ago
    [Ex]Admin Duncan's Avatar
    Here's the back of one.
    You can see the springy tab next to the straight edge (the one towards the back of the car). You simply pull/carefully prise that edge out and it'll pop out.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    cheers, thats given me a better picture, i'll try it tomorrow and let yous know how i got on.
    Gazza4
    Regular Member shan's Avatar
    Dave i changed mine the other day. I pushed the lens to the rear of the car, the side of the lens was level with the edge of the wing and then just lift it up at the wing side. It just pop's off. Then just twist the bulb housing out of the lens. Job Done.
    I also thought i was going to snap it but it's OK.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Hi all, cheers for the advice, got the repeater off no bother but was amazed to find - NO WIRE and NO BULB.
    Don't know if car was built like that of if the wire has fallen inside the wing.
    Gazza4
  1. Side Repeater Lenses...
    By Leemarksmith in forum Non Vectra C/Signum Album
    Last Post: 21st March 2010, 15:06
  2. Side repeater help??
    By Clugie in forum Styling
    Last Post: 22nd July 2009, 18:45
  3. Side repeater lens
    By Readster in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2009, 15:06
  4. N/S/F side repeater inop
    By OllyVXR in forum Electrical & ICE (including SatNav)
    Last Post: 16th June 2007, 15:59
  5. Side Repeater Colouring
    By Damian in forum Styling
    Last Post: 20th February 2006, 23:05
